Amana AKS3040 Gas Cooktop Logo
Posted on Mar 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Spark ignitor for two of the burners for the range on my free standing gas stove keeps "sparking" even after the controls valves are turned off.
Anonymous
Level 3:
  • Amana Master 43,501 Answers
  • Posted on Aug 19, 2010
Anonymous
Amana Master
Level 3:
Answers
43501
Questions
0
Helped
10844799
Points
101584
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Electronic ignitor on propane stove wont start
  1. Close all valves, including the one on the supply tank.
  2. Open valves SLOWLY starting with the tank. Safety valves are built in to prevent escape og gas if vales are broken off.
  3. Turn on ONE burner valve and, depening on the ignition type of your stove, light it. (some have an electric spark generated by a power outlet (120v) and make a sort of poping sound, some have a spark generated by a push button type mechanism.
  4. Once one burner lights, the others should light easily. Sometimes air gets in the lines, and this may have to bleed off, but it should only take a few seconds. -PS, make sure the stove is level, since gas tends to flow to the high spot.
1helpful
2answers
2helpful
The ignitor will not stop sparking.
heatman101
GAS STOVE
heatman101
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
GE ZGU650 EM1BG Gas Cooktop
On any range I've seen with electronic ignitors, the valves have a position that closes a contact to turn on the ignitor and manually moving the dial to the 'Hi' setting opens the contact again and the ignitor ceases to spark.
You don't mean the ignitors run even when the burners are off, do you?
I'm surprised to read that this has been happening for 'years,' the transformer for the ignitors must be really tough to withstand that and it doesn't sound like an electrode or transformer problem but rather a contact not opening as it should or you not advancing the control past the ignite point.
Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
5helpful
3answers
Ignition sparking repeatedly
I have a Creda gas stove ,yesterday some water boiled over. I have a continuous spark ever since and the stove is not even on. Is there any way to reslove this without calling a repair person?
May 01, 2008 • Cooktops
Top Amana Cooktops Experts
Paul Carew
Thomas Perkins
Thomas Perkins
Are you an Amana Cooktop Expert? Answer questions, earn points and help others
