I could not fully understand your description. Can you please ge tme an image so that I can see for myself what it looks like?
Ok.. That was better. From what you have described it sounds like a t-con board fault. What is the status of the sound? Also did you try another input mode and see if the problem persists? For example if you have this problem on HDMI did you try Component or S-video inputs?
Ok. Let me know how things panned out so that we can continue with the diagnosis if required.
Proview PA32JK1A LCD TV has bright area have a negative or washed out look. People's faces will look shimmering or negative look.
Customer tried different input mode from 480 to 780 no difference, will try the different signal mode and see if make a difference, Video or component etc.
Also sound is ok
