Okay this goes for the 3000 series remotes it might work for more. Press and hold the setup button until the red indicator light stays on'. Then release the setup button. Press and release the desired mode button (TV,VCR,etc) In your case it would be TV.The red indicator light then stays on.Then enter the four digit code. For a valid entry the red light goes off for a invalid code the red light flashes.With your device powered on push the channel up button if it works you are done. If some buttons don't work try some other codes.The codes are 0517, 0419, 0512, 0613, 0719, 0112, 0506, 0111, 0618, 0618, 0627, 0437, 0041, 0313, 0715, 0094, 0802, and 0111. And this helps you give me a vote please.
