Heat PumP: Rheem Two Stage Heat, One Stage Cool Thermostat Replac
Present thermostat: Rheem 41-20804-15 Present Wiring:
R = Power (transformer)
B = Changeover Valve (Heat)
E = Emergency Heat Relay
Y = Comressor Relay
W2 = Auxilary Heat Relay
G = Fan Relay
X = Power return
I want to replace the present thermostat with a Honeywell RTH7500D. I have the instruction manual but it is not specific. It would appear that the wiring would be as follows but I am not sure:
R = R/RC
B = O/B
Y = Y
G = G
X = C
L = L
E = E
W2 = Aux
Help!!!
Posted by geraldhumphr on
  • Bill Long Mar 11, 2014
    You are correct (R = power transformer) (B = changeover relay) (Y=Y) (G=G) (X=C Power return) (L=L) (E=E) (W2+W2)
Bill Long
    Guru:
  • 606 Answers
R = R with jumper to RC hot side of transformer
B = Reversing valve
Y = Compressor relay
G =Blower
C = common on transformer (X on old t'stat)
W2 = Auxillary heat
E = Emergency heat
Posted on Mar 16, 2010
  • Paulette Riley
    Paulette Riley Mar 08, 2014
    IT has RH,RC,Y,W,G ON THE NEW Thermostat.
Is there any process needed to implement for the summer to winter thermostat settings
You didn't mention what thermostat(s) you have but most simply require you to go from cool to heat and then check the temp setting(s0 to make sure they are in your comfort zone.
Nov 13, 2014 | Rheem Classic Series 95% Two-Stage Upflow...
Where is the low voltage 24 vac transformer located?
The transformer is located in the furnace. You might want to check to make sure the furnace door is on correctly brcause theres a swich that will open for safety . Also some have a fuse on the solid state board.
May 26, 2014 | Rheem RASL024JEC-RHPNHM2421JC 2 Ton 18.50...
Will a th5000 work with a ruud dual fuel
Are you talking about a pro 5000 Thermostat??? if so then NO it will not work.With this stat you do not have a temperature lock on the heat pump. Say you don't want the heat pump to run below 25 degrees. it won't shut the heat pump. And you don't want the heat pump to run at the same time as the furnace. With the Pro 8000 3 heat and 2 cool thermostat you can lock out the heat pump at 25 degrees outside an turn the furnace on. You will have to install an outdoor thermostat hooked up to the pro 8000 it usually comes with the stat. Honeywell products.
Nov 29, 2013 | Rheem 3.5 Ton 14 Seer / Ruud 100K Btu 80%...
Rheem Heat Pump Thermostat Replacement (#41-20804-15)
you need a 2 stage heat and cool t-stat hunter t-stat is not 2 stage
I’m happy to help further over the phone at https://www.6ya.com/expert/vincent_f7b7c5f4dedd2565
Feb 19, 2013 | Heating & Cooling
Cool mode well reverse ob valve to heat
On a Rheem the reversing valve engages on heat. On a Goodman (and most others) the Reversing valve engages on cool. You will want the thermostat to engage the reversing valve on the orange. There may be a switch in the thermostat that allows you to chose either O or B. Select O. If you have a choice of wire on the thermostat of either O or B than choose O. Also check and make sure the thermostat wire goes to the outside unit. Also make sure you have a thermostat that is comparable with your heat pump.
Jul 01, 2010 | Goodman CPLT24-1 13 Air Conditioner
New thermostat not cooling. Blowing heat instead.
Hello You have only 5 wires? multi stage if so ,is run by something else.Check that RH/RC is jumped out on new stat.Also check that O is not on the B terminal.If there is an A/B select switch set it to O.Emergency heat button dont matter as there is no wire to run it with only 5 wires.
Apr 17, 2010 | Honeywell Programmable Thermostat Heater
Need wiring diagram for Honeywell RCT8100
The old thermostat has a second stage heat which is W2. The new one doesn't have second stage heat.
The wiring your describing on the old thermostat is telling me you have a heat pump with second stage heat and the new thermostat is for air conditioning only. You will need to get a thermostat for a heat pump.
Apr 02, 2010 | Honeywell Electronic Programmable...
RTH7400 thermostat installed-screen display unlit-used page 10 wire installation. Used heat pump wiring-which does not show W2 and Y2 on heat pump schematic, so used conventional displayed W2 and Y2...
w2 and y2 are used for 2stage applications
w2 = 2 stage heat
y2= 2 stage cool
If your system is a single stage system, look for the y1 and y2 terminals. If the thermostat does not have y1 and y2 then you may have the wrong thermostat. As always, please read the directions carefully. Thanks!
Jul 03, 2008 | Heating & Cooling
Heating & Cooling Logo
2,677 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
