Question about Whirlpool RBS275PD Electric Single Oven
The oven does'nt seem to be able to heat up above 150, the fan is working, the bottem half of the oven does'nt seem to heating up. Is this fixable or do i need a new oven?
Posted by marcusandiss on
Ginko
  • Whirlpool Master
  • 19,396 Answers
Hi.
If the part that is not heating is only the bottom element, and the top element is heating regularly, then you may need to replace the lower element.
Before replacement the element can be tested removing it from the cavity and reading Ohms at the element terminals, with a multimeter set at Rx1. Disconnect power before removing the element.
If both baking and broiling element do not heath above a certain temperature instead, then the part to be replaced is the temperature probe, still located inside the oven cavity.
Regards.
Posted on Mar 04, 2010
1helpful
AEG double oven/grill stopped working
It appears the oven has shorted out. Try checking the breaker box and see if any switches have been flipped. If this is not the case a new oven is in order.
Jan 24, 2014 • Ovens
Have hotpoint single oven ,oven does,nt seem to get up to temp ie had it on full power 250 and placed a oven thermometer in and it only reached 150 any idea.nige
either the thermostat is faulty or the heating element is playing up ,check the wires as well in case you have a burnt/corroded terminal on the heater unit which is holding the amperage back
Grill working but oven won't heat up, fan working ok. Is it fixable and how difficult would it be to carry out myself?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 11, 2010 • Ovens
My oven won't heat above 150 degrees. Is this is
this can be problem with the temp probe.and or the control board if your unit is equipped.
Jan 23, 2010 • Ovens
We have a double wall oven which is 16 years old. The top oven doesn't heat above 150 and the bottom oven is overheating...the oven said 375 and an oven temperature gauge said 450. Is this fixable or do I...
I have the same issue. Only answer I found was the elements may be burned out. The bottom oven is separate (knobs).Go to GE site and see how to adjust the thermostat (behind a knob).
Bottem Oven Over Heats
GE announced a recall for some of its wall ovens this week for an overheating problem. Have you contacted a GE dealer yet?
Cooker
I just installed one in my house. I found that when you start the lower (gas) oven you need to turn the dial all the way on to 500*, push the knob in (you should hear the igniters clicking), then even when you see flames coming out of the burner, continue the ignition for 10 to 15 seconds. It should continue to stay lit thereafter.
1helpful
3answers
Oven not heating
there is more to this than meets the eye if youre oven takes a long time on fan setting it may be thermostat but more likely to be fan not turning at all or quickly enough the stat capillary is above oven element and if fan not blowing air away from capillary oven stat will shut oven temp down too soon if using conventional heat eg no fan make sure there are no full size trays directly on bottom of oven this will block heat from bottom element effectively giving only half the heat output.
hope this helps
My fan doesn't work
fan not fixable - replace. possible be that there is crap jamming the fan.check that the fan blade turns freely
Whirlpool RBS275PD Electric Single Oven Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
