Sony KDF-42WE655 Television Logo
Question about Sony KDF-42WE655 Television
Can anyone replace a cable tuner
Fuzzy picture, only getr one channel, cable guy said its the cable tuner
Posted by danoo746 on
Donnie Wayne Sharp
  • 132 Answers
I bought a 42" Akai TV that really was just a monitor because it didn't have a built in tuner. I dug up an old vcr hooked my cable up to it and plugged rca cables to the composite out on the vcr to the composite in on the tv and set the input on my TV to run off that input.I was able to change channels through the vcr it worked like a cable box. Thats just an idea that could save some bucks. Oh yeah, if you do this make sure you get an older vcr that has a tuner in it.
Posted on Mar 04, 2010
I have a sony 27 Trinitron with tuner issues. the picture is fuzzy/snowy on most channels. I have inspected the cable coax and it is not an issue. the problem started shortly after an electrical storm. I...
The RF amplifier in the tuner has been damaged. You will need to replace the tuner. A suitable replacement tuner from a wrecked Sony tv would be you cheapest option.
Best regards Vintie
2answers
Cable picture is fuzzy
Call your cable company as there might be a problem with the drop line or aerial coming into your house. now another thing is if you have a signal splitter( ex: 2-way, 3-way, 4-way) before the cable box, that could be degrading the signal as each input may drop the signal significantly. remeber, don't use too many splitters as they will make the signal faded/fuzzy. also, make sure all the connectors are clean and are not badly bent or the ends frayed. If you can see wire insulation from the cable line then it's no good.
My vizio tv works fine with the dvd and the wii, but when hooked up to the cable it is fuzzy and picture flashes. I unhooked cables and replaced all of them as well as replaced hdmi cable. The picture...
Ur Main Tuner signal board have problems,that cause of this.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner signal board for the replacement.
1helpful
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
1helpful
On my cyberhome 1600 dvr want to view tuner of dvr on tv screen
Take your TV for a check by a good technician. Some IC have short circuited in the accident that occured.
Rate this...
Channels 3,4,5,6 no picture
i have seen this on our cable system at the shop. it could be the system of most likely the tuner in the unit is haveing issuses.
One channel fuzzy
Tis is an ongoing problem I seen increase alot over the past few months. From what I can gather, all the channels being broadcast over going from the analog to digital, there's no big suprise to anyone. However, the change from analog to digital is changing at a faster rate, so when you look at the TV some channels will be fine and others will have grey lines, fuzzy picture. The only solution-you need a TV with some kind of digital tuner. On the TV itself if the (TV has one) it will say "SD" or "ED" which stands for standard digital or enhanced digital.
Bad Cable Input
Try using your RCA imput to see how the picture looks compared to the tuner picture,is possible your tuner imput is bad,make sure the conector is not loose,the overall picture should look different but not fuzzy all over,using a dvd picture thru the aux (rca)imput should show you the difference.If the conector is loose only it could be repaired but if it is solid the tuner might be bad and it will need to be replaced along with any board it might be mounted to.Let us know how it goes or if you need more information.
Open Questions:
Top Sony Televison & Video Experts
Jaime Hernandez
 Grubhead
Grubhead
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
