Canon PIXMA  MP530 All-In-One InkJet Printer Logo
Posted on Mar 04, 2010
Canon MP530 Error 5C10 showing. Can't find print booklet. Help
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
154
Points
Can't solve it, but I have it. My Canon has not booklet print option when it's used as a wetwork printer, but it does when it's connected directly. Why?
5C10 faulth in my MP530 Pixma. Who knows the answer(s) Tanks
There is no error 5C10 listed in the MP530 service manual. however count the sequence of how the green and orange lights flash. Repost with this info and i can help you more.
1helpful
I have a Canon PIXMA MP530 printer and showing an Service Error 5C10. What is that error? It will not print and the Alarm light flashes.
disconnect it from power for 10 minutes and also check for jammed paper. That should do the trick
Rob
Ps. Thanks for ratings.
I am trying to print on my Canon MP830 and I have had two error messages. 5C10 and 5100. I don't know what these errors are can you please help?
There seem to be a number of involved suggested fixes for the 5C10 error code.
Please go to this web page, and click the "Service and Support" link.
This will display a "Please enter your question" field. Type "5C10" into the field and click the Search button.
The first entry displayed will be a link to "ERROR LCD: Error Code 5C10" -- click the link
Three new links will eventually display:
  • Press ON/OFF switch to reset the multifunction device
  • Removing paper jams MP800R / MP830 / MP530
  • The MP830 may require repair
Click each link to see if the solution provided is appropriate to your situation.
2helpful
Service error 5c10
This error is a message indicating print head/ink failure on the printer.
I would try the following 2 things:
1. replace the ink cartridges/print heads. test to see if the problem is fixed.
2. If this does not solve the issue, you may need to either send it to the manufacturer for repairs (if under warranty), send it to a local repair person to service- or look for a new printer to buy (which may actually save you money).
I keep getting error 5C10 and can not print anything. Have turned it off and on and still doesn't work.
1helpful
I have an MP530 printer - error message 5C10 is
You could try resetting the printer:
1) On the panel, press and hold the <On/Off> button until the display goes blank (approx. 1 second). If the display does not go blank, unplug the power cord.
2) Wait approx. 10 seconds, plug in the power cord (if removed in previous step), press the <On/Off> button to power on the unit.
3) Wait for the printer to cycle through its startup routine before trying another print job.
I hope this helps!
1helpful
Error code 5C10
From Canon. Issue: ERROR LCD: Error Code 5C10
1. Press ON/OFF switch to reset the multifunction device 2. The MP530 may require repairI would remove the print head and inks,unplug it completely from thr eall for a half hour.Plug it back in and install everything.
MP530
The alarm light is blinking. It says Error 5200? What is that?
Email me at : [email protected]
old marine
old marine
ZJ Limited
ZJ Limited
