Question about Baby Gear
Converting from crib to toddler bed
Posted by kdellagnese on
Anonymous
    New Friend:
  • 78 Answers
It is very simple to convert a crib to a toddlers bed. You just need to remove the side railings by folding them under the bed. It would be automatically converted to a bed that a toddler can use please might you rate me or vote for me
Posted on Mar 04, 2010
Snooze Bed
    Habit-Forming:
    New Friend:
  • 100 Answers
If you were having trouble changing your crib to a toddler bed, it may be best to look at alternative bedding options such as https://www.snooze.com.au/collections/kids-bedroom/beds.
Posted on May 09, 2019
5 Related Answers
Anonymous
SOURCE: converting crib into toddler bed
Call customer support @ 18002951980 and customer support can either email or fax instructions at no charge. I just did it and got the instructions myself. Or you can email me @ [email protected] and I'll foward the instructions to you.
Posted on Jun 20, 2008
Anonymous
SOURCE: i need to know how to convert it to a toddler bed
The front rail just comes off and then the toddler is able to get in and out.
We did this with ours and it worked out great.
Posted on Nov 14, 2007
Anonymous
SOURCE: Crib to toddler bed instructions
I need instructions to transform my mama and papas Aspen Cotbed into a bed! We have lost the instructions! Can u help?
Posted on Oct 17, 2008
Anonymous
SOURCE: Jardine Crib 4 in 1
step 1: detach the front panel (part j) from the front posts h(1) and h(2) using allen wrench
Step 2 if mattress support (part K) is not in the lowest position, unscrew mattress support bolts (Part d) from the post and move it to the lowest position
Step 3: Using the wrench provided, attach the guard rail (part f) using 4 bolts (part a) between the left and right front posts
Step 4: tighten all screws clockwise.
good luck
Posted on Oct 24, 2008
Anonymous
SOURCE: convert crib to toddler bed
I finally found my instructions!! It's actually really easy to convert to a toddler bed:
Step one: Take out four screws (two on each side) of the front railing and top bar. They are the screws holding the front railing and the top bar to the side of the crib and the dresser.
Step two: Lower the mattress to the lowest setting.
Step three: Place the toddler bed railing in place. It can go either way depending on which side of the crib your toddler sleeps. We put the taller part of the toddler railing closest to the dresser because that is where our son's head usually is.
Step four: You'll need 4 1.5 inch hexagonal screws to screw in the toddler railing. After 2.5 years, I could only find two of them, so I used two 1.5 inch regular screws that came with the crib. On the taller part of the toddler railing -- the screws go into the 1st and the fifth holes. On the shorter side of the railing, the screws go into the 3rd and the 5th holes.
That's it.. You've now got a toddler bed!
Posted on Jan 10, 2009
Are there different types of toddler beds or a standard type in different styles?
There are quite a few varying types of toddler beds in the market. The first kind I will mention is a convertible crib. The great thing about a convertible crib is that it will last much longer. Some parents also find that a convertible crib eases the transition phase. Next there is the "captain bed" also known as a storage bed. This bed has built-in compartments everywhere - under the bed frame, in the footboards, even in the headboards. There are other types of toddler beds such as loft toddler beds, futon toddler beds, and platform toddler beds; however I think they are less popular and ultimately less safe for your toddler.
Jul 19, 2012 | Baby Gear
How can I convert my baby's crib into a toddler bed?
This is a little tricky to explain; however I found you a great how-to article that will guide you through this process. Hope you find it helpful!
http://tlc.howstuffworks.com/family/how-to-convert-crib-to-toddler-bed.htm
Convert hadley crib into toddler bed
I can't find you an answer that is specific to the hadley crib but take a look at this article which explains generally how you convert a crib to a bed.
Jul 08, 2012 | Baby Gear
Converting crib to toddler bed. i bought this system used and don't have all instructions
Don't worry, there are instructions online that will talk you through the process of converting your crib into a toddler bed. check out this article from the 'How Stuff Works' website which is really useful.
Jun 23, 2012 | Baby Gear
I have a vickie crib .I want to convert to toddler bed. If I take the front rail off there is'nt anything to hold the bed up in the front. It unscewss from the side. Help! Bed was purchaced 9/2008 ...
Is this a 4-in1 convertible crib? The Toddler bed will need the bottom railing and a half rail to convert from a crib to a toddler bed. The half rail can also be removed to make the 4th conversion to a toddler bed with out railing. But to convert this specific bed you DO have to add the bottom rail that came with the bed at purchase.
Mar 10, 2011 | Sorelle Vicki
Does the da vinci convertible crib convert to a twin size bed, or does it just go toddler to full?
This Model only goes from Toddler to Full Size with conversion kit.... http://www.milliondollarbaby.com/collections/emily
The Emily Mini Crib goes to Twin bed.
Jul 11, 2010 | DaVinci Emily Crib
How do I convert from a crib to a toddler bed? Do
Mar 03, 2010 | Sorelle Regal 310 Crib
How do you change the graco 5 in 1 convertable lillian crib into a toddler bed?
Mar 03, 2010 | Graco Ultra Deluxe 5-in-1 4605 Crib
Need directions for converting crib to bed
It is very simple to convert a crib to a toddlers bed. You just need to remove the side railings by folding them under the bed. It would be automatically converted to a bed that a toddler can use please rate me and vote for me please
Mar 03, 2010 | DaVinci Kalani M5501 Crib
I would like to convert my Simplicity crib #8748 from a crib to a toddler bed.
Mar 02, 2010 | Simplicity for Children Ellis 4 in 1 Sleep...
Baby Gear Logo
2,343 people viewed this question
Top Baby Gear Experts
Marvin
Marvin
Paul Carew
john h
Are you a Baby Gear Expert? Answer questions, earn points and help others
