Question about Kal Equipment Battery Tester - KAL Equipment
I broke the plastic cover on my 4260, wher can i get another cover
Posted by dleach2 on
Anonymous
    New Friend:
  • 11 Answers
Any electrical equipment shops
Posted on Mar 04, 2010
I have a '99 ford ranger broke a pin on shifter in steering column... when I took of cover around column it pulled a black and purple wire with a blue crescent shaped plastic clip with a copper tab out...
This is your pats transceiver. I don't know if this helps? I looked at info for 3.0L--99--ranger. You have to remove steering column cover to get at it. Also, note the wiring for transceiver. I didn't see wire color you mentioned? You might be able to go to your local dealership and talk to their service department, or call them. See if they have a transceiver in stock that they will let you look at and compare it to what you have?
Jul 08, 2017 | 2001 Ford Ranger Regular Cab
The clear plastic cover that covers my screen broke
There are several different sheets of plastic that cover your screen. The outside one is the screen protector, the middle one is the lenticular screen, and the inside one is the fresnel screen. All are available at Encompass.com
Apr 22, 2010 | Toshiba 61H71 61" Rear Projection...
Broken outer cover on Jabra Bluetooth headset with ear hook.
no i don't think but go to the store wher u got it or call the counpney theat it is frfom and tell them the problem and they my get u a new 1
Jun 07, 2009 | Jabra Bluetooth Headset with Adjustable...
Plastic strap broke
No plastic straps are usually not covered by warrenty. If you live next to a ski resort with a shop im sure they will have a replacement for about 10 buck MAX. Otherwise check at your sporting goods stores(I know scheels carrys them).
Mar 24, 2009 | All Star Bent Metal Biscuit ++ Snowboard...
My surjetteuse does not make its curls anymore
finally I decided to make it repair by a specialist near me
thank you
Mar 21, 2009 | PfaFF Hobby 4260
Fuel pump fuse
the fuel pump fuse is located under the hood on one of the fender walls. there is a plastic covering over it, take it off it is in a little box.
Jul 02, 2008 | 1996 Pontiac Firebird
Luggage carrier slats for 2008 chev. equinox
I purchased them but did not have them installed. the instructions seem simple. 1 with flat bedded tool pry the plastic covers up. 2 open the latches on the crossbars and slide them into position. 3 replace plastic covers. I have not yet try to install them yet with the same worries of scrathing or damaging the covers. The illustration shows th entire cover to come up but does not give a hint to wher you should pry it from.
Anty other info would be appreciated.
Jun 14, 2008 | 2008 Chevrolet Equinox
Toshiba TP61G60
Hi.
I have toshiba TP61G60 projection TV and accidently broke the 61" grey plastic screen which is covering a glass screen.
Does anyone know wher to buy that screen?
Apr 15, 2008 | Televison & Video
Kal Equipment Battery Tester - KAL Equipment Logo
196 people viewed this question
Top Kal Equipment Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Kal Equipment Measuring Tool and Sensor Expert? Answer questions, earn points and help others
