Try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
You may have a bad cell in the lcd display, Plug an external monitor to your laptop to see if its working. If it works well, you will need to replace the lcd. Not cheap
SOURCE: laptop fell off moving vehicle and now the screen
You should contact the manufacturer. The laptop is broken. Make sure you don't tell them it fell from a moving vehicle.. Probably not the best way to start or end that conversation. I'd go with... "It worked yesterday, but today the LCD wont display anything".. You're not lying. Either way if it's under warranty you're more likely to have it fixed. Otherwise, the LCD replacement is almost always more costly than simply replacing the laptop. Best of luck!
