Question about Sewing Machines
METAL PLATE COVERING BOBBIN WON'T STAY DOWN
SINGER CG 550
The metal plate covering the bobbin, keeps popping up when I sew anything....I took the two little screws holding that little black plate surrounding the bobbin holder off the other day, and lost one screw...but I did put two screws back into it. Now the plate won't stay down. I've broken two needles already trying to sew. I don't know what else to do. It worked fine before I looked into that little hole, now it has a problem...what can I do?
paj42
    Genius:
  • 1,116 Answers
Take it apart again and compare the original screw with the one you substituted. If they are not the same size, you will need to get one that matches the original.
Re-place the needle plate and when firmly in place, put the screws back in.
Posted on Mar 03, 2010
Testimonial: "Thanks paj42. That seems to have fixed my little problem...."
2 Related Answers
ken dourof
  • 980 Answers
SOURCE: SINGER CG 550
If the plate is moving up and down eithetr the teth are set far too high pushing the plate up or the teeth are set too far forward, I would go for the first, if the teeth are coming up well above the slot they are too high, they should be set so that when you look alongside the plate you can just see the top of the teeth, you can adjust the teeth by adjusting the screws underneath the machine where the teeth are.
Posted on Mar 07, 2010
Anonymous
SOURCE: Problem w/ metal plate over bobbin
try and find the screw dude... either that or try taping it down i know it's not an ideal solution but it's a quick fix until you can replace the screw
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Dec 13, 2015 | Singer Sewing Machines
How do I get the plate to close all the way after winding bobbin on the Singer 6235
When you wind your bobbin the center metal tip in the bobbin causes the bobbin to raise or lower. If you press on the center tip, you'll see that it is actually a spring that goes up and down. It sounds to me like that metal tip is stuck down in the bobbin winding position, which is not allowing the bobbin to settle down all the way! You might also check to make sure that your needle is at the highest point, and you have selected #2--the straight stitch. I learned all this from the instruction manual on page 14; it is available as a free download from the singer sewing machine site, and if you don't have one I would recommend that you get it--it's most helpful.
Jun 17, 2014 | Singer Sewing Machines
Model CG-550. Needle hits a bottom plate. All thread and bobbin removed. Took the feed cover off. Do not see the problem.
Possible bent or wrong needle. If ok, check the zig-zag mechanism to see if it has come uncoupled from the needle mechanism. Good luck!
Oct 02, 2010 | Singer CG550 Mechanical Sewing Machine
Mar 07, 2010 | Sewing Machines
New Problem...I have a Singer CG-550. When I try and sew anything, the needle hits something inside where the bobbin is. The little black casing holing the bobbin keeps moving all over the place, I slip...
On the right of the black bobbin case there are two screws, you can slacken those screws off and move the bobbin case nearer to the guard leaving enough room for the thread to pass through, if the needle is hitting the bottom you may need to retime the machine.
Mar 06, 2010 | Singer Sewing Machines
SINGER CG 550
Mar 03, 2010 | SINGER 7470 Sewing Machine
Bobbin case and threading singer 6423
This machine has a black plastic bobbin case. You drop the bobbin down into the case with the thread coming off in a clockwise direction. If you look close you will see a slot in the bobbin case where there is the metal pieces. The thread will slide into that and as you pull on it it will work its way through and come out on the other end of the metal. Lay the thread over top of the bobbin case and turn the handwheel to pick up the thread. (make sure you close the slide plate)
Feb 07, 2009 | Singer 6423 Sewing Machine
Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Jun 20, 2008 | Sewing Machines
Need to replace a bobbin cover plate
Here in Australia, the dealer would get it in for you. The 'manufacturer' / distributor usually don't get involved with customers! I'd find a dealer near you and ask!
Oct 08, 2007 | Sewing Machines
Sewing Machines Logo
252 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
