Not enough heat
I bought 4 baseboard heaters. two were installed upstairs on a separate thermostat and breaker, and two downstairs (again, on their own identical thermostat and breaker). Maybe it's just me, but it seems the heaters upstairs heat up considerably more than the two downstairs. when I place my hands over the heaters upstairs, I can really feel the heat coming from them.
I can feel the heat coming from the two heaters downstairs, but it doesn't seem to be anywhere near as intense.
  • Anonymous Mar 03, 2010
    I think the problem was because I daisy-chained (sorry, I don't know the proper electrical term... 'series' wiring?) the baseboards and they were (somehow) sharing power. I've since ran each on it's own line from the thermostat and I have all kinds of power now.
    I'd understood from my baseboard heater manual that doing this was ok, but doing what I did above seemed to fix the issue.
Chandler Ede
  • 1,420 Answers
Take an Amp draw on all heaters and compare. If within 5%, they are working fine but you may have more open area downstairs than up.
Posted on Mar 03, 2010
2 level townhome- the upstairs is heating to 68 degree-thermostat is located but the downstairs is like 58 degrees.The vents are open in ceilings downstairs. How can we do to get more heat downstairs
close ceiling vents
the hot air down stairs rises through the vents and adds to the upstairs heating
same as hot air goes up the stairs to the upper rooms
Dec 27, 2017 | Heating & Cooling
My upstairs temperature is 80 degrees and the downstairs is 69 Honeywell focus pro th6000 is set at 69. Why is the upstairs so drastically hot?unit is located upstairs& thermostat is downstairs
if there is no control of air movement between floors and you have it on cooling then any cold air will go down to the lower floor
or alternately if you have it set on heating all the hot air will rise to the upper floor
where is the system located (upstairs or down stairs ) and where is the thermostat located
to get control close any upstairs to down stairs doors or erect a heavy curtain across the stair well
Dec 17, 2016 | Honeywell Heating & Cooling
How to set heat for baseboard heat
They use a 120v thermostat you should be able to buy one wherever you bought the baseboard heaters. Be aware those heaters costs a lot of money to run and dry out your house like a desert buy a few room humidifiers when you get the thermostat. Make sure you use the correct size wiring to the baseboard heaters and the Tstat if you undersize the wires for the breakers involved you'll more than likely cause a electrical fire.
Oct 01, 2014 | Honeywell Heating & Cooling
I am interested in purchasing baseboard heaters, particularly I have been looking at the Farenheat PHH15002 baseboard heaters. I am purchasing an 1100 square foot 2 story condo with 2 bedrooms and a...
#1 you have to calculate the heatloss of your rooms,that will tell you ur wattage require. Oil filled or not,it's just as dry. As far as ur load to panel breakers, a rule of thumb is approx 3600 watts for 20 amps,using a number 12 wire. But ur wall heaterS should suffice
Apr 21, 2017 | Fahrenheat PHH15002 Oil Filled Baseboard...
I have 2 Thermostat's in my home. My heat works well upstairs but not downstairs. My thermostat downstairs won't come on but I unhooked the thermostat from downstairs and tried it upstairs and it worked...
Hi, sounds like you determined the problem is not with the thermostat. That leaves the furnace that serves downstairs. What type heating system do you have?
Jan 13, 2010 | Honeywell Programmable Thermostat Heater
I've noticed two problems with my heating system, but not sure if they are related. Here's the background - sorry for being so long winded. Background: I have a Weil-Mclain Gold CGi Series 2 (which was...
Two problems, one is a bad thermostat on zone 2. The second is the boiler. The inducer fan energizes causing a pressure switch to engage. This pressure switch energizes the ignitor. If the ignitor does not get hot enough, it will cycle again all over. The cheapest route to take is to check all hoses going from fan housing to pressure switch looking for bad connections or leaks, the second thing to do is to replace your ignitor (time for it anyway).
Jan 05, 2010 | Heating & Cooling
I can only get heating to the radiators upstairs, not downstairs
balance the rads.
upstair radiators turn all valves off,heat will then divert downstairs,open valves upstairs 4 turns on locksheilds and number 4 on trvs if u have any.
then if that does not work get a combi or powerflush.
if u cant afford then drain a little from rads,get x300 sludge remover from plumb shop and put in header tank(not hot water tank).
then fill system up and repeat balancing.
www.jollygreenplumbingmachine.co.uk
Dec 26, 2009 | Desa International CBN30T Central Heating...
Heating blowing coo air downstairs and warm upstairs?
Some of this depends on where the air handler/furnace is located. Most often in two story houses, it's in the attic upstairs, or in a closet upstairs. A duct routes air from the furnace to the downstairs supply duct, so it is a distance from the air handler.
When the unit first initiates a heating cycle, that duct is going to be full of cool air, and the duct itself will be cool. So the furnace has to run long enough to push the cool air out, as well as warm the duct up, before your going to feel warm air at the registers downstairs.
Keep in mind, heat rises. And, your thermostat only monitors the immediate area where it's located. In your case, upstairs.
Two story houses are problematic because of this. And one way around it is to have a damper system installed that distributes the air upstairs or downstairs based on a thermostat located in those spaces. There would be 2 dampers, and 2 thermostats (one upstairs, one downstairs). Each stat would control a damper, and the call for heat or cooling.
Let me know if you would like to consider a system like this, and I can point you to components to use. I've put several system like this in.
Jan 26, 2009 | Kitchen Appliances - Others
High Electrical bill - Appears to be heatpump problem.
Sound like there are running on emergency heat which is elrctric.Have the system checked out buy a local heating and cooling company. Have they checked the filter and changed them.
Jan 14, 2009 | Honeywell Electronic Programmable...
Electric baseboard heat not getting hot
Is your fuse box and main power source large enough to handle the full load if all are turned on at the same time? Are you uses two pole breakers? you might only be feeding with 110 volt. This would prevent them from getting very hot.
Jan 03, 2009 | Heating & Cooling
Heating & Cooling Logo
230 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
