Tip & How-To about Computers & Internet
It is very easy to deal with UAC Settings in windows 7.You dont need to completely disable UAC, if you really dont want to do. Here is the step to be followed to disable UAC in windows 7 Step
1: Access UAC settings by typing UAC in the start menu or control panel search
OR
Go to start -> Control panel - > user accounts
Once you double click on user accounts you will get a window like below. There double click on Change user account control settings option
Now you will get options to change user account control settings. You can move the slide to 4 different posiotions according to your choice. The first is more secure and the last means its disabled
Disable UAC via Registry Editor
1.Type regedit in the Start -> Search bar. 2.GotothefollowingKey:HKEY_LOCAL_MACHINESoftwareMicrosoftWindowsCurrentVersionPoliciesSystem 3.Locate REG_DWORD: EnableLUA
4.Set the value of EnableLUA to 0.
5.Locate REG_DWORD: ConsentPromptBehaviorAdmin
6.Set the value of ConsentPromptBehaviorAdmin to 0
7.Restart
Disable UAC via Group Policy
Windows Vista
In newer versions of Windows, User Account Control (UAC) is implemented to warn users when they are about to complete an action on the computer that could cause damage.
However, these warning messages can become bothersome. Disable UAC to prevent warning messages from being displayed constantly as you use your computer.
Click "Start," then click "Control Panel."
Double click "User Accounts."
Click "Turn User Account Control on or off."
Remove the check from the box, and click "OK." You may need to restart the computer to complete this change.
Windows 7
Find the search box at the top of the window and type "User Account Control" into it. This will result in a link labeled "Change User Account Control settings." Click the link.
Move the slider to the bottom of the window to disable UAC warning messages completely or to a position in the middle of the window to disable warnings in only certain situations.
Hope this helps
