Question about Texas Instruments TI-84 Plus Calculator
Where is the equal sign on the ti 84 plus - Texas Instruments TI-84 Plus Calculator
Posted by sure0400 on
Anonymous
  • 136 Answers
Hello sir, Press "second" "math", and it should be the first thing listed. If you need other commands hit "second" "0" that will enter the catalog and you can press any letter (without hitting alpha) to jump to that letter in the list. Please click on the following link to see the manual of the TI-84 Plus Calculator: http://education.ti.com/guidebooks/graphing/84p/TI84PlusGuidebook_Part2_EN.pdf
kindly rate me.. thanks for using fixya..
Posted on Mar 03, 2010
Anonymous
    New Friend:
2-(2x-5)=2(x+5)-2
Posted on Nov 10, 2010
Anonymous
    New Friend:
How input formulas and solve variables
Posted on Mar 09, 2010
Anonymous
    New Friend:
The enter button is the same as the equal button
3 Related Answers
Anonymous
  • 11 Answers
SOURCE: graphing multiply equations
When you go to Y=, you should get a list that says:
Y1=
Y2=
Y3=
etc. You just enter the first equation into the Y1= space then hit ENTER and it will go to Y2=. Enter the second equation there. After you have entered all of your equations, push GRAPH and they should come up in order but they will all appear.
Also, make sure your window is set appropriately so that you are able to see all of the graphs.
Lastly, when you look at your Y= screen, are there funny looking arrows before the Y=? If so, do this:
  • Press [APPS] key
  • Select Transfrm from the menu
  • Press 1:Uninstall
  • Hope one of these are helpful!!
    -Gretchen
    Posted on Mar 22, 2008
    Anonymous
    • 11 Answers
    SOURCE: I do not know how to find the greater than and
    press 2nd, then math. It will bring you to a menu with =, not equal, >, <, and that kind of stuff
    Posted on Mar 18, 2009
    k24674
    • 8081 Answers
    SOURCE: My TI-84 Plus won't graph two functions at once.
    Turn the satistical plots OFF
    Press [2nd][Y=] (STATPLOT). Select or enter 4: to execute the command [PlotsOff] [ENTER]
    Clear the lists (statistical lists)
    Press [2nd][0] (Catalog]. Press [PGRM] C. The cursor jumps to the first command in catalog that starts with C (The greek letters in names do not matter). Scroll down a bit to reach the command [ClrAllLists]. Select it and press [ENTER].
    Try your graphs again.
    If you still have problems, just reset the RAM:
    Press [2nd][+] (MEM). Press 7 to select [Reset] then [1:All Ram][2:Reset]. Press [Clear] to erase the Ram Cleard message.
    Now you should be able to draw the graphs.
    Hope it helps.
    Thanks for using FixYa.
    Posted on Nov 19, 2009
    How to use an equal sign in a problem with multiview ti-30xs
    You cannot. To evaluate an expression (not an equation or an equality) key it in and press ENTER.
    May 09, 2014 | Texas Instruments TI-84 Plus Silver...
    How do you use the equal sign on the ti-84
    The equal sign of the TI83/84/Plus is a relational operator like less than , greater than, less than or equal to) You use it when you are testing if two values (numbers, expressions, or matrices) are equal.
    For example, if in one your programs what you do at a certain time depends on the equality of two expressions, you test the equality by a statement :
    If A=B do this action.
    Jan 30, 2012 | Texas Instruments TI-84 Plus Silver...
    How do you type an equal sign on the TI 84 calculator
    On these units, the "equals" sign ([=]) is located in the [TEST] menu. This menu is a [2nd] function of the [MATH] key.
    This function is used to test if two expressions are equals. To evaluate an expression, simply hit [ENTER].
    Good luck.
    Mar 01, 2011 | Texas Instruments TI-84 Plus Calculator
    How do you fine the equal sign on the ti 84
    If you need it for a comparison test, it's the first item on the TEST menu. Press 2ND TEST 1 to get it.
    If you need it for something else, please reply to this post specifying the purpose.
    Oct 09, 2010 | Texas Instruments TI-84 Plus Calculator
    You can access the = sign through the CATALOG of command.
    Press [2nd][0]
    Use Up arrow to scroll through the Catalog index from the bottom. You will eventually find the = sign.
    Sep 21, 2010 | Texas Instruments TI-84 Plus Calculator
    How would you enter the following equation to graph on a TI-84 Plus Silver Edition calculator? 2 <= t <= 9
    To enter the inequation you split it into two inequalities
    Graph is as follows
    Use [2nd][CATALOG] to access the relaional operators less than or equal, greater than or equal, and the operator AND.
    To access the inequality signs scroll upwards from abs( to reach the bottom of the catalog.
    Note: You can use t as variable only in parametric graphs. Use x.
    Hope it helps.
    Oct 19, 2009 | Texas Instruments TI-84 Plus Silver...
    I need to use the equal sign
    One: just press enter/solve
    Two: press 2nd Test (Math) then press enter
    Mar 04, 2009 | Texas Instruments TI-84 Plus Calculator
    I do not know how to find the greater than and equal to sign on the ti-84 silver plus calc
    Feb 28, 2009 | Texas Instruments TI-84 Plus Silver...
    Texas Instruments TI-84 Plus Calculator Logo
    18,171 people viewed this question
    Top Texas Instruments Office Equipment & Supplies Experts
    Ekse
    Scoee Scoffer
    Edward Easley
    Edward Easley
    Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
