Question about O2 Samsung SGH-E250 Cellular Phone
The phone is stuck on restart loop... - O2 Samsung SGH-E250 Cellular Phone
Posted by slarrabee on
Mohsin Idrees
    Guru:
  • 302 Answers
Maybe your power button is shorted out. Also it can be a software problem. Contact your local mobile repair man.
Posted on Mar 03, 2010
Stuck in loop mode
You should properly flash the GAPPS too.
Otherwise it will restart continously.
Jan 15, 2014 | Samsung Galaxy Ace GT-S5830
Zte score stuck on muve music screen loop
Hey i've been workin on these ZTE phone and i guess all u need to do is a reset. But the only problem is u will lose all ur data. all u gotta do is First power off the handset, press the Camera key + Power on key +Down volume key together at the same time.
when restart the handset,When display "ZTE", press the Menu key at the bottom of the screen;
Choose "Wipe data/factory reset" through volume key
Press "Camera" key to confirm the above item
Choose "YES...delete all user data"
Choose "reboot system now", handset will be restarted automatically and all the user data will be erased.
Now once its done ur phone will automatically configure all the factory setup and should work fine,
Apr 09, 2013 | ZTE Score
Pcd venture restart loop
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Sep 10, 2012 | Virgin Mobile PCD Venture No-Contract...
My cherry mobile nova android phone keeps on powering on and off every 5-15 seconds, what should i do to stop it? i can not use my phone because it will keeps on restarting
Your phone is stuck in a "Boot Loop". This was most likely caused by a newly installed update, program or an unfortunate virus. Start by removing the battery for about 30 seconds. Push down on the power button while the battery is out, to release all memory from the board. Re-install the battery and turn the phone back on. If it is still stuck in the boot loop, you will need to perform a master reset.
WARNING!!! A MASTER RESET ERASES ALL DATA ON THE PHONE AND RETURNS IT TO THE ORIGINAL FACTORY SETTINGS!
PROCEED AT YOUR OWN RISK!
Master Reset for your device is done by turning off the phone. Then press and hold the camera button + volume up + power button. Keep holding even when the phone turns on. Navigate with the trackball, scroll down and click on Wipe data/factory reset. Hit yes to confirm everything and let her rip.
Dec 20, 2011 | HTC G1 Cell Phones
Iphone 3g problem with just a apple sign? 100% battery Not charging after going dead!
Are you stuck with just the Apple logo? Did you jailbreak your phone because the apple logo stuck is a symptom of a tethered jailbreak. If yes, you should run Redsnow to get you out of the apple logo loop. If not, try to do a hard reset first by holding the home and sleep buttons for at least 10 seconds until it restarts.
Let me know if you still have problems. :)
Mar 11, 2011 | Cell Phones
Hard drive won't reboot. Stuck in a loop.
start the machine press f-8 select "safe mode" press enter run chkdisk/r
May 22, 2009 | E-Machines eMachines Desktop PC
Palm 650 stuck in loop
you have to hard reset it. Remove any software that you just install.
May 21, 2008 | Palm Treo 650 Handheld
Nokia E61 Boot Failure
I had this problem once. My problem was due to a file (currupted) in my memory card. I found this out by restarting the phone without the memory card. once the phone was up and running, i looked for the damn file and deleted it...
Mar 26, 2008 | Nokia E61 Smartphone
O2 Samsung SGH-E250 Cellular Phone Logo
158 people viewed this question
Top O2 Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Jean Thiebaux
Are you an O2 Cell Phone Expert? Answer questions, earn points and help others
