Posted on Mar 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have 4H Error in my SHARP AR-5516N.Please give the solution
abbas rezazadeh
Level 2:
  • Expert 328 Answers
  • Posted on May 30, 2010
abbas rezazadeh
Expert
Level 2:
Answers
328
Questions
Helped
88442
Points
530
Iput code (# interrupt C interrupt) led turns off .input 14 press copy
65helpful
6answers
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
1helpful
Sharp 5516 n legal duplex copying is not coming
Duplex unite only use a4 size not other size.You can try other size before configure.
4helpful
2answers
My sharp copier AR-5316 has the problem. Error code 4H appear and cannot copy.
Hello sir; You need to do a reset procedure as follow; Press "#", "interupt", "C", " interupt". then enter 14 press start, machine go back to normal.
20helpful
4answers
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
2answers
Error h4
it is on you fusing unit of your copier, check the fuse maybe it is open already and need for replacement... H4 means that your heater lamp is not functioning
franklin
Display messege 4H how to solve pls
Its an error indicating the fuser isn't at the right temperature. It could be a thermistor that went out. It should be looked at to see what needs to be replaced.
2answers
ERROR CODE 4H ON AR-5316
There is a problem with the fuser unit ( exit where it gets hot), unfortunately you need to replace
either 1- thermofuse, 2- thermistor, 3- heater lamp
67helpful
13answers
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
