MP3 Player, Model M4202. I get this error message when trying to initiate: Init EZDockConfig.xml failed
SOURCE: Problems with LG MP3 Player (due to a mistake in the operation of the device)
Hi, everybody
I had the same problem, and i found this page.
Just, there is a problem, who knows chinisse jejejejej
if any body sould traslate this wold be helpfull.
http://www.coolnstyle.com/DownloadDetailCmd.laf
SOURCE: Rio Nitrus MP3 Player
Ok Rio nitrus is great litle thing, and I had the same problem. This is what you should do:
1) download latest firmware for rio nitrus http://www.rioaudio.com/support/rio/downloads/Nitrus/RioNitrus_firmware_123.exe
2) unpack firmware
3) connect Rio Nitrus to your comp;
4)While holding menu buton press power button, you sholud see on display showing UPGRADER text;
5) Then upgrade the firmware ( note that this will erase all the songs- read the read me file that come with firmware);
Although I allready have the same version of firmware v.123 like the one that upgreded this solved the problemm.
SOURCE: Boot error on mp3 player model 4008a
Reformt the player:
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
SOURCE: M4202 shows "Initializing" message for 5 sec. and blocks itself
This is the firmware going bad.
You need to go to the RCA website and download the firmware for your player.
After you download the firmware.
Connect your mp3 player to usb device of your pc.
Then install the the newly downloaded firmware.
