Question about Aspire Digital AD-1000 DVD Player
Connection using Component video No Video
1. First try. Use red,green blue for video, red and white for audio. sound but no picture
2.Second try, Yellow composite for video, red and white for audio, sound and picture
I planned the composite video for my VCR, which lacks the component Red,blue green outputs that are present on the DVD player, so now I cannot hook up the VCR
1 Related Answer
SOURCE: DVD player Model AD-1000. No video using composite
When using Component Video you MUST use AV for the Audio in ALL circumstances. Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
Posted on Mar 03, 2010
2answers
I have a 2003 Kawasaki 5 disc dvd player and can't figure out how to hook to rca new tv
The yellow (video), red (right audio) and white (left audio) leads on your DVD player connect to the corresponding inputs on the rear of your RCA TV.
2helpful
2answers
What channel or setting is used on the TV to play a DVD?
Hi, Channel 3 or 4 might work for older TVs. Most new HDTV's have a mode setting in the menu. (Video 1 or 2 or 3) or (Component 1 or 2). On your remote you may have DVD button. Try all these suggestions, 1 of these will work. You can play with the remote too. Good luck.
1helpful
The DP26649 model TV has three inputs; video one (which is fine and has all color and everything), video 2 (if you plug them in certain ones the best i can get is full sound and all but its black and...
OK, here is the breakdown on whet you are doing wrong.
Video 1 - Composite -
Video - Yellow
White - Audio In - Right
Red - Audio in - Left
Video 2 - Components - HD - RGB = Red, Green, Blue
Video -
Red - Red Colors
Green - Green Colors
Blue - Blue Colors
Your GameCube will only work on Video 1, unless you buy an HD (Component cable). You will need to buy HD cables for your device connected to Video 1 to work on video 2. I will assume it is a DVD player. This is a high definition cable to produce a better picture. Let me know if you do not completely understand
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
With the use of rca/video cables and the Samsung composite cable, how do I connect to an audio/video receiver(surround sound)
There are alot of different options when it comes to your connection basically , it comes down to quality and what in and out jacks are available to use. To me 'composite cables" were always the red, white, yellow combo where, yellow is video and red and white are l/r sound. "Component cables" were always red blue and green. The component cable provides a higher quality picture but, does not carry sound, like composite. To gain sound using component cables, you have to add either your yellow composite or a digital optical cable, again, depending on what your system will accept. HDMI carries both audio and video at the best quality and is easy. To answer the question for what you have if you have "composite"(red, blue,green) this will provide the best picture but, you will have to use the red and white "composite" for sound.
No colour
Hi, Definitely a TV issue for me. Changed Wii to another input on TV and resolved situation. Need now to check how to get my TV to recognize colour on AV2 & 3 because I prefer to keep DVD input as AV1!
I had to use the (RCA) video inputs and not the component inputs. These are the ones made for video games. If you want to use the component input (Component cables are Red,White Red, Green, Blue). If you don't have any, you should be able to purchase them at your local electronics store like Radio Shack or Best Buy. Hope this helps, read below:
TV (This is your cable connection or TV; coax)
Component 1 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
Component 2 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
HDMI 1 (HDMI Cable)
HDMI 2 (HDMI Cable)
Video 1 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Video 2 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Sample of Component Cables:
http://www.tigerdirect.com/include/AddCartfromGallery.asp?EdpNo=245214&csid=ITD&Sku=C184-27083&imgcart=1
2helpful
The picture is green
Make sure that the unit is connected to the tv properly. Be aware that most dvd players have six connections. You can connect the unit to the television using RCA cables (yellow, white, red) or RCA sound with component video (white, red, blue, green, and red). When using the yellow-white-red method, the sound is carried by the white and red cables and the video signal is carried by the yellow cable. If you're using the white-red-blue-green-red method, the white and one of the red cables carries the sound, and the blue-green-red cable carries the video signal. This connection uses one cable for the green component of the picture, one for the blue, and one for the red. Make sure that the cables are connected properly and you don't have the two red ones mixed up. Connect Sound-R to Sound-R, component R to component R, etc. If that doesn't work, you may be able to adjust the picture on the tv. There's still a chance that the machine is defective.
How do i hook up a nintendo to my tv which cords go where and can someone walk me through it
Round peg into the round hole. Red peg on the red slot. etc. If the wire from the nintendo doesn't fit the slot on the tv then you're in the wrong slot. if the wire from the nintendo fits the slot on the tv (and is the same color if you are using red/white/yellow rca cables) then you're good. here's a hint on connection types (you will not mix): 1. RCA (red/white/yellow round connectors) Red=right audio sound White=left audio sound Yellow=video connect to the slots that look like they want some. 2. Coaxial (stiff cable with a pinner poking out of the end -- same cable that connects you to cable tv) just hook it up by itself; it carries audio and video. 3. Component (red/green/blue)(red/white) two 'bundles' red=red component of video green=green component of video blue=blue component of video red=right audio white=left audio 4. VGA + (red/white) VGA=video (computer monitor cable) red=right audio white=left audio 5. HDMI (flat hdmi cable. you spent $30 on this 3 foot ****) HDMI=audio and video 6. hugs and kisses hugs=video kisses=audio (both sides)
1helpful
2answers
From cable box component out to tv component picture is on no aud
You need to also connect the RCA audio out (red/white) from your source to the audio input on the TV. You do not need the yellow wire as that is for composite video. The component cable (red/green/blue) is only for video. Look at the input on the TV where you connected the red/green/blue cable. Right next to it, you should have another red and white connectors for the audio input. Connect that to the audio out on the cable box.
12helpful
Connecting a wii system to a sanyo DP26648 tv
It has to do with the type of input - Video2 and 3 are Component video inputs, requiring a 3- wire component video cable (Red,blue,green for video, red/white below for audio). Video 1 is for analog equipment (Yellow for the video, red and white for the audio). Unless your Wii comes with a component video out cable and jacks (same red blue green), you'll have to use video 1 for the Wii, and use Video 2 for the dvd. You'll need a component video (3-wire) cable for your dvd, which should have the jacks for it. You can use the present cable you're using for the dvd, but you'll have to change the connections on the back of the dvd to component video out, and you'll still need another 2-wire cable to connect the audio out on the dvd to the audio in on Video 2 on the tv.
Here's the manual for your tv - look on page 8 for these connections. the Wii will be an analog connnection, the dvd will be a digital connection.
http://www.sanyotv.com/DP26_32648%20Owners%20Manual.pdf
Hope this helps!
6helpful
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Aspire Digital AD-1000 DVD Player Logo
Top Aspire Digital Televison & Video Experts
Ekse
Are you an Aspire Digital Televison and Video Expert? Answer questions, earn points and help others
