Question about Kwikset Powerbolt/Electronic Deadbolt- Polished Brass
Have a Remote Keypad model 898 that has stopped opening the door. Led on door indicates it is receiving a signal. Keyfobs work. What is reconnect proceedure?
Posted by netmb3 on
2 Related Answers
Coaltowner
  • 963 Answers
SOURCE: i have a kwikset deadbolt
I was searched but was unable to find any information on the model 898 keykess entry set.
I therefore suggest that you call Kwikset's Customer Service; I'm sure they can help you:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Kwikset Corporation
Consumer Service
19701 DaVinci
Lake Forest, CA 92610
Kwikset Customer Service
Call: 1-800-327-LOCK (5625) Fax: 1-800-713-7080
Support Hours: Monday-Saturday
7:30am-4:00pm PST
Closed Sundays and Major Holidays
Posted on Mar 10, 2011
Jan Berardi
I had the same question as my son installed the lock. Instructions should be printed on the cover you remove (inside the house). They need to make removing that cover MUCH easier, I'm always afraid I'll break it. Anyway, you press the button once for the first number. To enter a "guest" code, press the button twice then enter the 2nd code in the keypad and press the lock button. Now try both main # and guest #, both should open ttthe lock.
Posted on Sep 30, 2011
Garage door send receive signal
Caution: do not use LED bulbs with garage door openers. They are a possible source of signal interference between the transmitter and receiver on the opener.
Mar 22, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman Garage Door opener model # 139.53674SRT2. It is sporadically going up and down to varying degrees. The LED indicator on the back is constantly blinking. If I trip the motion sensor it...
Rapid blinking of that LED indicates it is receiving a signal. Make sure you don't have an old remote somewhere that is sending a signal and that your other remotes do not have a stuck switch. Remove the batteries and check that light.
Jul 17, 2011 | Sears Craftsman LiftMaster Chamberlain...
Moved to a place with a 139.53975SRT1 Garage Door and Keyless Entry. Keyless entry stopped working and I cant get code to operate door. All remotes stopped working. Reset codes with Learn button,...
Try this method for programming. Press and hold the button down on the remote while you press and immediately release the learn button. Do this for each remote.
Have you replaced the battery in the keypad? Try this:
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Post back with your results.
Jan 14, 2011 | Sears Craftsman LiftMaster Chamberlain...
My wireless remote keypad stopped working. I changed the battery and it worked to get the garage door down but not up. The key pad is about 7 years old.
It sounds like your keypad is going bad and has a weak signal. It can operate the opener with the door open but with the door between it and the receiver it can't.
May 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
When i push remote control, the green light flashes on the back of the unit, but garage door doesn't open.
The flashing LED shows that it is receiving the radio signal but the code may need to be set. Try programming the unit and see if that works for you.
Jul 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote doesn't work!!!
You could try to replace batteries. May be they are stong enough to make the LED flicker, but not strong enough to send out a proper signal to the receiver.
Mar 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door close with wireless remote entry but will not open
It sounds like this remote has lost its program! you will have to reprogram it!I hope this helps ya!
Dec 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Kwikset Powerbolt/Electronic Deadbolt- Polished Brass Logo
965 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Charles Tidwell
ray gallant
STEVE SPAM REMOVER
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
