Sony KP-51WS500 51" Rear Projection Television Logo
Posted on Mar 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There is a convergence problem . color distortion.
Chi Chu
Level 3:
  • Sony Master 8,457 Answers
  • Posted on Mar 03, 2010
Chi Chu
Sony Master
Level 3:
Answers
8457
Questions
0
Helped
2820884
Points
26282
Know how to solders?Replaced the 2 convergence ICS,some or all the resistors.Tries Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
The picture is distorted as well as the color
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Alignment of the bulbs to converge
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2answers
Image of picture has blue color overlaping the other colors
Symptoms:
  • Colors wont align
Color distortion in an Akai ( Cheaper model Rear Projection tv) I
Ur convergence is dead.Try Tv repair World.com.
Buy a whole convergence board replaced it.
2helpful
51" sony projection with distorted pic and color
The convergence amplifiers are likely blown.
Fairly easy fix if you are good at soldering.
Search this site for convergence repair.
Dan
2helpful
Picture is all distorted ,colors dont match up need 3d glasses to watch
HI, this is basic convergence failure. the convergence board controls the RGB stream and , if its malfunctioning or, the convergence chip set is damaged, it will distort the entire display and the colors will not be regulated correctly as you are experiencing at this time.
simply replacing the convergence board in this unit will fix your issue.
Convergance,and distorted projection,colors will not align
These tv's have a separate convergence power supply that goes bad. This will cause the problem you are having. Depending on the age of your tv, the board may be available
1helpful
Sony KP-53XBR35 TV Concave top & Bottom in wide screen, along with color distortion around sides
thats usually a convergence IC failure, Are you able to move the red and blue colors in the convergence adjustment menu?
Distorted image and color
sounds like the convergence ICs have failed. Will the red and blue move in all 4 directions when you try to adjust the convergence? If not the convergence ICs are bad replace both of them also check the resistors that power the ICs as they may be open as well.
Picture distorted and blurry with color
bad convergence amp ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
