Question about GE 24 in. GSD4000J Built-in Dishwasher
SOURCE: GE Nautilus dishwasher wont run
getting ready to try what everyone suggests......wish me luck
Posted on Nov 11, 2008
This is a typical GE problem which I have seen many times...When a DW sets for a while not being used...the motor often freezes up....Take the front (lower panel off....find the motor assembly...(with the DW unplugged!!...very important)reach in with you hand or a screw driver...preferably your hand...at the back of the motor...there should be a impeller blade...you should be able to reach in with a finger and pull it down..it may be resistant so find a way to hold it in place as you reach up to the next impller blade and pull down further...finally it will all of a sudden free up....after which you plug it back in and start it up...I am also including a step by step (no drain problem check list as you may run into an issue like this if it has not been operated for a while ....notice article # 5).
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to
see if it is clogged. Unscrew the top cap and see if there is anything
blocking inside. Note: If there is no air gap installed, the dishwasher
might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there
is an air gap installed, it is very common that a hose going from the
air gap into the garbage disposer is clogged. Remove and clean the
hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it
might not be broken, it is recommended that you replace the belt,
because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller,
takes care of the wash cycles, the other, drain impeller, drains the
water out. If the drain impeller is broken (broken blades, shaft), the
dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to
drain water out. Sometimes the solenoid gets stuck, preventing the
water from draining out. Try to free up the solenoid. If unsuccessful,
you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
I hope this helps...it is always useful to include the Model #...more specific instructions can then be provided
Good Luck and good day.....please rate my effort...the Fang
Posted on Mar 28, 2009
SOURCE: dishes just are not getting clean its seems like
You may not have enough water entering the dishwasher and need to have the water valve replaced. Try adding a quart of water during the wash cycle to see if it makes a difference.
St. Paul Appliance Rescue
Posted on Dec 23, 2009
SOURCE: I have a GE GLD5860L15SS Quiet Power 2 dishwasher.
Sounds like a motor overload switch. You may have a bind on your motor or a clogged water pump. Try removing the kick plate and take a look underneath. You'd be amazed at what can end up under a dishwasher.
Posted on Mar 07, 2010
SOURCE: ge quiet power 3 dishwasher
Ok guys, I just had this gigantic piece of **** malfunction on me, exhibiting the same behavior as described - buttons doing nothing.
I looked online and apparently you have to hold the "time delay" button, and the "light wash" button at the SAME time for THREE seconds. You really have to push those suckers in hard, thanks to GE's awesome design on this panel.
After I did that I slammed my fists against the panel pretty hard about 8 times in a fit of rage. Magically the damn thing beeped and I was able to configure my wash (Pots and pans, heated dry, blah).
Whew! Sadly I rent my house, so I stuck with this abomination.
Posted on Dec 21, 2010
Sep 28, 2011 | GE Dishwashers
Jul 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Nov 11, 2009 | GE JKP15 Electric Single Oven
Oct 04, 2009 | Sony Video Game Consoles & Games
Sep 29, 2009 | Canon BJC-85 InkJet Printer
Jul 03, 2009 | Intex Automatic Salt Water System for ...
Mar 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Oct 09, 2007 | General Electric Adora GHDA670N Built-in...
Dec 19, 2010 | GE 24 in. GSD4000J Built-in Dishwasher
