Question about Sony FD Trinitron WEGA KV-27HS420 27" TV
WHEN TV IS TURNED ON IT IMMEDIATELY SHUTS ITSELF OFF. THERE IS A RED LIGHT FLASHING IN THE FRONT RIGHT CORNER BOTTON
Posted by ken_e_odom on
Anonymous
    New Friend:
  • 3 Answers
My sony tv blink 5or6 time and it wont turn on
Posted on Mar 09, 2010
ABRsvcs
  • 4,234 Answers
The light is hte standby light and it should be blinking a repeating count. That count will indicate the defective circuit. Please post the count and confirm your model to be KV-27HS420 and we can look up the code and provide the probable repair solution.
Thanks,
Dan
Posted on Mar 02, 2010
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
Screan shuts off after 30 seconds and 3 lights flash on botton near power button.
Contact Samsung tech support, Tell them this info, they should be able to tell you the type of problem you have
Feb 12, 2014 | Samsung HLP5085W 50" Rear Projection...
Our 50" plasma has a
The television shuts itself off and the light blinks in the front to protect itself when something is wrong with it. It will come back on a few times when unplugging and replugging but by doing that and not getting repairs done it has gone into a coma and will most likely not turn on again until it has been serviced. You can try leaving it unplugged for several days to see if you can get it to come back on.
Nov 29, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
The tv has power .the red light is on ,but when it turns on,the green light comes on but then it turns right back off ant the light goes back to red it has a round 1/2" button like plastic plug in...
Tod,
The little plastic button you are referring to is the IR receiver for the Remote. When the TV turns itself off, are there any flashing lights on the front or rear of the unit. Look through the vents in the rear for any flashing lights or try tuning the tv on in a dark room and see if any lights flash and reflect off of walls. If there are flashing lights tell me how many flashes and what color and I will try to look them up in the manual.
Nov 02, 2010 | Pioneer PDP-425CMX 42 in. Plasma...
Free big screen, is it worth it to fix?
take the front cover off.two hidden screw at each corner or on the sides .now take off cover in middle of set.two the right you'll find a small box , it will have 3 adjustments on the top and three more at bottom.the bottom ones are your screen controls.the middle is your green and on the right is the one you turn counter clock wise.warning ...turn that control a hair .that will solve the problem
mr.tv.inc
1-866-217-6788 harry
Feb 18, 2009 | Sony KP-57HW40 57" Rear Projection...
I need the code to program my dish network remote for the Polaroid 42 inch LCD television
press and hold the tv botton on you dish remote till all the lights light up release the tv botton it should stay flashing then hit the larger of the two red power bottons next you will need to hit the up arrow one at a time till the tv shuts off when the tv shuts off you then hit the # botton at the bottom you wiil see the tv botton flash your code will then be saved
Dec 02, 2008 | Televison & Video
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
TV LED Flashes then TV shuts itself off
capacitor problems in power supply or a regulater isolate the power suppley by disconecting the line output stage/unplug scan coils for example and run a 60w bulb as a dummy load one wire to earth and the other to rail voltage colecter of line output transister if the bulb glows steady the power supplys fine
Jun 25, 2007 | Philips 27PT81S 27" TV
Sony FD Trinitron WEGA KV-27HS420 27" TV Logo
289 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
