In an ECS G320 notebook have a built into the motherboard broken and therefore do not charge the battery. How can I send a photo of the location to give me the same feature?
Hi, There is nothing much that can be done to speed up the system as it can not go beyond 1GHz Processing speed, but several operating system tweaks and some hardware upgrade could make a little but notable difference. As for Hardware, you may increase the RAM. You can upgrade memory on ECS Elitegroup Computer G320 upto a maximum of 1.0 GB (The ECS Elitegroup Computer G320 takes the PC2100 DDR SDRAM SODIMMs
Memory) Secondly, You may increase the size of PAGE FILE, uninstall unwanted software, Remove unwanted start-up items, Clean Junk Files/ Temporary files, De-fragment the Hard Disk to achieve the maximum speed and performance that EliteGroup G320 PC can give.
Hope it helps! Good Luck! Thanks for using Fixya! CreativeTECH
- go to device manager
right click computer if your using win 7 and click properties click device manager on right side
- try to uninstall the keyboard driver and restart your system
- hope this works
First, you need to make sure your power adapter is providing enough
power to both run the laptop & charge the battery. A very good way
to do this is to compare your laptop voltage & ampere requirements
(written on a sticker on the bottom of the laptop) with the voltage
& ampere ratings of the power adapter. Voltages should be the same,
or the power adapter's voltage about up to 0.5 volts more than the
laptop's voltage rating. Amperage of the power adapter should be at
least equal to or greater than the laptop's rating. It should never be
less than the laptop's rating, or else the power adapter will be
providing insufficient amperes to charge the battery. Of course, the
power adapter's nominal amperage might be ok, but it degraded on usage.
You can verify this by testing using a good or new power adapter. If
the battery did not charge using the new power adapter, take the battery
off the laptop, & using a dry tooth brush, scrub in between the
fins of the battery connector on the motherboard & on the battery it
self, then put the battery back into the laptop & try again. If
this still did not resolve the problem, then the battery itself could be
bad. Try it on another laptop, or try a good or new battery in your
laptop. If this did not work, there might be a possibility that the
charging circuitry on the laptop's motherboard is defective & needs
servicing. In order to do this, the laptop needs to be disassembled
& the motherboard checked for defective/burned out components in the
area near the DC jack. Any defective/burned out components found should
be replaced, or you might need to replace the laptop's motherboard
altogether.
Sounds like there is a disconnect between the power in and the battery, probably a broken solder joint or a fuse. Unless you are a tech, send it in for repair.
