Well you can click on start then settings go to Today then Items and see if the Htc sense is checked or not. It should be checked and your problem will be solved. If still no help then you can hard reset your phone. Method to do Hard Reset is turn off your phone and while holding the volume keys up and down press the power button and it will take you to the hard reset screen now if you press volume up then you phone will be hard reset and come back to factory settings but you will loose all the phone book and other data on the phone. I hope this will help.
You can go to settings then Today and click on the items and see if the HTC sense is checked or not. Its should be checked and your problem should be solved. If still no luck then you can Hard Reset your phone. By doing this it will delete all the data on your phone and bring back the factory settings. Its will not harm your storage memory card data. To make a hard reset you have to turn off your phone and while holding the Volume Up and Down button press the power. Now it should bring you to the Hard reset screen. It will ask you to press the volume up to do the hard rest. I hope this will solve your problem.
not worke still
