Toshiba Satellite Pro L300 Notebook Logo
Posted on Mar 02, 2010
Hello my laptop seems to be looping
Hello my laptop seems to be looping configuration stage 3 0% of 0% complete can u help? have tried safe mode doesn t work???
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Mar 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
1709
Points
11
Try with the Last Known Good Configuration. if that does not work. back up imp files frm the desktop, My Documents n C:\ drive. perform a repair installation on the C:\ Drive alone. this should fix the issue. as some boot files are corrupted.
How do I stop my laptop from reboot loop?
Just insert a windows CD and repair your OS. Your problem will be solved while preserving all your files and folders! Good luck
I tried to open in Safe mode and got this screen and then back to the configuration stage 3 screen and then shut down - on loop.
You can use a repair disk to fix the problem, or there is another brilliant sollution.
If you have another computer you can use for internet access and a 2GB flash drive then take this option. Believe me it has its uses and it may come in handy one day.
>> Hiren <<
1helpful
My computer is stuck in the configuring updates: stage 3 of 3 - 0% complete.
give it some time to install that update, if its still not working then might be possible that the update was not downloaded properly or it got corrupted while installation due to which its stucked on stage 3 of 3.
In these situations we can try to restart the computer into the safe mode and and then check which update is causing the computer to stuck on stage 3 of 3. If possible try to kill that update in safe mode too. To help you on that you need to provide me some more information.
Which operating system are you using?
1helpful
Stage 3 of 3 0% complete same ol same ol dell 1501 help
http://www.ditii.com/2008/02/18/how-to-get-windows-vista-sp1-out-of-configuring-updates-stage-3-of-3-0-infinite-loop/
My computer is on step 3 of 3 of system updates -
It seems to be that Update was not done properly.
When computer is booting up, press "F8" key continuosly, it will bring you the Windows where you can find option say " Safe Mode". Enter in Safe mode.Once you logged into the Safe mode, go to start-->Settings-->Control Panle-->Add or Removbe programms -->Click on View upates right hand side and remove all lates update. --< Then Restart computer. It will fix the problem.
How do I get my Acer 5500 to boot from my uTorrent recovery disc?
Do you have your original recovery media for Vista? Sounds like you're going to have to repair the installation.
1helpful
Cannot get out of Configurating updates: stage 3 of 3 screen
This is all I could find:
It's not only Windows Vista Service Pack 1 that isn't ready for general consumer availability. Some of the updates released on February 12, 2008, as a part of the Microsoft monthly patch cycle, have managed to effectively kill Windows Vista. Users are reporting that, following the introduction of the February 12 updates, Vista gets stuck at the finalization of the deployment of the updates displaying the message "Configuring Updates Stage 3 of 3 0% completes" and then entering
an infinite reboot loop. And there is absolutely no way out for the end users, because canceling the configuration process of the updates is a move equivalent to losing access to the operating system entirely. This will even happen in Safe Mode.
Microsoft has yet to officially respond to the issue, or to provide a resolve or at least a workaround. However, it does seem at this point that there is an issue with the deployment of the pre-requisite updates necessary for the smooth installation of Windows Vista SP1. Namely, the problem resides in the Vista installation software. The fact of the matter is that end users will have to first update the Vista installation software and only then deploy the remaining February 12 updates and only at the end Vista SP1 RTM.
If you are stuck watching the "Configuring Updates Stage 3 of 3 0% complete Do not turn off Computer" and in the endless reboot loop, then stop the cycle and boot from the Vista media. You will need to "Repair your computer," so select your Vista installation and restore it to a point before the deployment of the updates. After gaining back access to your operating system, you will have to install the service stack update, namely Update for Windows Vista (KB937287). Deploy this update before any other on your Vista, and only then install the rest. At this point in time, you should experience no more problems.
"Update 937287 is a prerequisite package that contains updates to the Windows Vista installation software. The installation software is the component that handles the installation and the removal of software updates, language packs, optional Windows features, and service packs. Update 937287 is necessary to successfully install and to remove Windows Vista SP1 on all versions of Windows Vista," Microsoft revealed.
Acer Aspire 5630
Seems like your VISTA upgrade didn't sucessfully upgrade itself from XP to VISTA. Seems like M$ update program detects your OS as XP and tries to install the SP3 for XP. VISTA only has SP1 released. Its currently stuck in a loop that it doesn't know what to do. Restart your laptop into safe mode by pressing F8 before the VISTA loading page comes up and go to Safe mode and backup your data and use the ACER RESTORE CD OR ACER RESTORE METHOD to help you reload your system back to factory defaults then upgrade back to vista without install any updates or connecting it to the internet.
This is my best solution to get you out of this weird and unusual situation.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
