Question about Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum
How do you change the belt on a dyson DC 07 - Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum
Posted by meibert1 on
Samyfam
  • Dyson Master
  • 379 Answers
DC07s have two belts - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
I suspect the belt you are to refering to is the one from the clutch to the brush bar. Unfortuenately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available on eBay reasonably cheaply, but again good tools and DIY skills are required.
Have a look at www.dysonmedic.com which has some excellent info on dismantling and repairing your machine, but unless you have access to such tools, and feel confident to tackle it, it's probably time to call Dyson or a Vacuum repairer.
Posted on Mar 06, 2010
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: roller brush is not turning on a dyson DC14
http://www.dyson.co.uk/support/help.asp?product=DC07-SY&article=527
here's a link that might help
good luck
Posted on Dec 29, 2008
Anonymous
  • 83 Answers
SOURCE: Dyson DC-07 Hose Wand Spring Came Out. How to put back in?
You'll see that there is a round piece with a cross shape on the inside of the button wand release button - place the end of the spring over the cross - you'll see the same cross on the collar of the machine...it'll take some doing, but line the other end of the spring up with the cross and pop the button back into place - be sure to click it onto those two gray circular/oval shaped divets at the bottom where the release button connects to so that the button stays in place.
Posted on Jul 30, 2009
Anonymous
  • 5 Answers
SOURCE: Replace dyson 07 animal brush roll assembley
The end caps of the brush assembly which contain the bearings are only a push fit onto the spindle (quite tight). Remove these and the brush bar will pass through the drive belt loop. To achieve this the belt has to be stretched slightly so care has to be taken not to over-stretch what might be a belt getting to the end of its life. When refitting the end caps do not forget to aline them properly so they fit into the sole plate recesses correctly.
I cannot see at the moment how to replace the drive belt on the DC 07 without significant dismantling (that will probably be my next job) I do not see the use of the Dyson tool you offered.
Posted on Oct 27, 2009
vacwater
  • 175 Answers
SOURCE: how do I change belt on dyson dc 07 animal
You can't change the belt. There is a factory tool that is needed to do it.
Posted on Dec 02, 2009
Anonymous
  • 167 Answers
SOURCE: how do you change the belt on a dyson DC 27
Hi its Darran at Dyson.
The belt on this machine is part of the clutch mechanism and as such we only recommend that a suitably qualified engineer carries out any repairs to this.
If you would like to talk through the options with one of our advisors, please contact our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 19, 2010
Why has new belt on DC 07 broken immediately after replacing
check and clean the brush bearings located on each end most reasons that belts break is the brushes are binding from debris --others bad belt or old and dried out
Aug 26, 2016 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do I fix the carpet brush on my dyson dc14 vacuum?
this is what is is broken it is the clutch Dyson clutch belt assembly for DC07 amp DC14 900252 04 473
most likley needs to be changed it is also a good idea to change the roller brush at this point also
Dyson Dc 07 14 33 Upright Models oem 904174 01
Jun 12, 2016 | Dyson DC14 Animal Bagless Upright Cyclonic...
DC 07 brush bar not working
The brush is driven by two belts and a clutch. Your belts on the clutch are stretched. Their are several youtube videos for rebuilding and replacing a DC07 clutch. Just change the blets don't buy a new clutch. A lot cheaper to change belts. You might as well clean everything up while you gave it apart. Have fun.
Jul 07, 2014 | Dyson DC25 All Floors Bagless Upright...
Brush doesn't spin
This model has Brush Control
The Brushbar can be turned off to protect rugs and delicate floors
You've either accidently turned the brushbar off or the belts broken
Apr 08, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
How do I change belt on dyson dc 07 animal
Dec 02, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
The brush doesn't spin anymore, but the belt is not broken. model DC 07; approx three years old
The belt may not be broken but after 3 years the belt will have stretched and it will not turn the brush. You should change the belt every year. Changing the belt is an inexpensive fix. I would try that first and if it doesn't do the trick I would take it to a repair shop. You can get the belt you need here:
Dyson DC07 Replacement Belts
Nov 07, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Oct 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum Logo
784 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Mike
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
