Question about Akai LCT2060 Television
I have a tv that only shows variations of blue and yellow no matter what i do to the menu color options. However the menu will show all of the colors but not the normal screen.
  • Anonymous Mar 02, 2010
    We are just playing HD cable through the tv. I think it is weird that the tv will project the green, blue red and yellow colors on the menu options but not when it is displaying the tv show.
Duke
    President:
  • 1,284 Answers
If you are connected to a HD cable box, I suspect it is via component cables and the red connector has come loose at one of the ends.
Posted on Mar 02, 2010
Anonymous
    New Friend:
  • 4 Answers
It sounds like an rgb problem it depends what your playing thru your tv but if its coming thru a component lead eg red green and blue it sounds like your missing the red feature also it could be a pin bent on your scart which is carring the red portion of the picture , What kind of set is it and what are you playing thru it ?
LG tv shows av inputs as black & white
you need to plug all three colors in not just yellow
red blue green need to be pluged in their respective colors
Nov 28, 2009 | LG 27LC2R 27 in. LCD TV
Black and white
Your not getting color probably because of a weak "air" signal. The fix is a better antenna or an antenna booster.
May 08, 2009 | Apex Digital PF2025 20" TV
Wii only shows blue, yellow and black on my HD TV
Are you trying to plug in the yellow, red ,and white cables into blue, green, and red slots? If you are you cannot because those are for HD inputs only
May 06, 2009 | Nintendo Wii Console
Only color is yellow and blue
go to menu & select the picture mode with standard
then go to detail setting , change the off-set value of r(red)
Oct 17, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
New system - no color on screen
the cable colors have to match the tv ones if you have different colors on cables then look for the label on the cables saying video or audio (red)=audio (white)=other audio (yellow)=video EXAMPLE if the cable colors are different than the tv then if the label on the cables say video and the color is blue etc. then you have to put it on the yellow putin on the tv no matter the color. If it dosent work then try holding the cables in many angles try pulling them or anything unlit they work get something to hold them up if that dosent work then i think you should buy new cables. [email protected] for more questions
Mar 29, 2008 | Nintendo Wii Console
My tv ?? aarrrggghhhhh
Atech will need to go into the SAM mode and check the option code in the set.
Mar 12, 2008 | Philips 60PP9202 60" Rear Projection...
Blue and yellow color
Blue should converge on top of "yellow".Bad connection(s)
on blue convergence IC.Replace both IC's for durable repair.
Check pico fuses.Reset convergence alignment.
Oct 17, 2007 | Samsung HCL552W 55" Rear Projection...
Akai LCT2060 Television Logo
113 people viewed this question
Top Akai Televison & Video Experts
Marvin
Marvin
matt martin
matt martin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
