SanDisk Sansa View 8GB MP3 Player - Black Logo
Posted on Mar 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you download music on your sandisk?
How do you download music on your sandisk sansa
Anonymous
Level 2:
Guru:
  • Expert 82 Answers
  • Posted on Mar 03, 2010
Anonymous
Expert
Level 2:
Guru:
Answers
82
Questions
Helped
24869
Points
113
I know how to load music to sandisk sansa player.
NOTE: If you're using a MAC, see answer ID 1141
METHOD 1 - Load and sync music files using Windows Media Player
METHOD 2 - Copy & paste or drag & drop music files to the player through "My Computer".
1. Connect the Sansa player to the computer.
2. Double-click My Computer.
3. Locate and select the music file(s) to be copied to your Sansa player .
NOTE: You can select multiple files by holding the CTRL key down while clicking files. You can also select all the files on that particular folder by holding CTRL key then pressing A.
4. On your keyboard, hold the CTRL key then press C to copy.
5. Under My Computer, double-click the Sansa player.
NOTE: If the Sansa player is connected in MSC mode, you will see something similar to the image below:
If connected in MTP mode, you will see something similar to this:
how do you download music on your sandisk? - id100-2.gif/uploads/images/id100-2.gif" alt="id100-2.gif" class="h_mi" />
6. Locate the Music folder and double-click to open.
NOTE: In MTP mode, you may need to double click on Internal Memory to gethow do you download music on your sandisk? - id100-3.gifan> MUSIC folder.
7. Hold down the CTRL key on the keyboard then press V to paste the music files.
If you want to enjoy more music and video on Sansa Media Player, you can try this guide.
5 Related Answers
Anonymous
  • 43 Answers
  • Posted on Nov 18, 2007
SOURCE: Sansa Media Converter
I would start here. I hope you registered the product...
http://www.sandisk.com/driverdownload/driverList.asp
Anonymous
  • Posted on Dec 31, 2007
SOURCE: i need help
You can simply drag and drop songs to it, or you may like to use Real player version 11. I suggest you use Real player, 'cuz it can directly convert a video that you may download from youtube to your mp3 player. It is the best for me.
Jean Sintulaire
  • 759 Answers
  • Posted on Mar 25, 2008
SOURCE: SanDisk Sansa m230
I would recommend that you update the firmware on your device..that usually solve the problem you are having..To update the firmware, follow the link below..
http://www.sandisk.com/DriverDownload/download.asp
I hope that helps
Please rate accordingly
Thank You
Computerrep
YourZEN
YourZEN
  • 820 Answers
  • Posted on Sep 02, 2009
SOURCE: I just bought a Sandisk Sansa clip 1GB MP3 Player.
Support for Sansa Clip:
http://www.sansa.com/support/sansa_clip/faqs
User manual for this device can be opened with adobe reader:
http://www.sansa.com/sites/default/files/downloads/CLIP_UM_0608_ENG.pdf
RixsFixes
Radio Code Pro
  • 2200 Answers
  • Posted on Jan 01, 2010
SOURCE: how to download music to sandisk sansa
Please view my FixYa Tip on this subject at this link which covers the common issues.
Many thanks for using FixYa.
I have a SanDisk Sansa how do I download the music from my Imac to the Sansa, I've connected it to the Imac but I don't see how to downlaod the music
Is the SanDisk showing as a drive on the Imac? You should be able to drag files from the Music folder to the Sansa player to copy them. (You can't connect to ITunes and download directly to the player.)
I hope this helps.
5helpful
2answers
How install a driver for Sansa e260
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...run the programs follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
3helpful
How to put music in a sandisk sansa
Download the Manua; after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer2.gif is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
You can make another music folder (music1)put music in this....
1helpful
How to download music from my computer to sandisk
To Sansa m200 series manual in pdf format with this link:
http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
Use the provided USB cable for connection.
For transferring music to the player you can use the next software.
Windows Media Player; how to use WMP see:
http://kb.sandisk.com/app/answers/detail/a_id/389
Trouble getting the software for my sansa sandisk c200 series mp3
I am also a user of SanDisk. They will not give any CD with it. Try using below steps to download the music.
1. Movies and Music should be in MP3 format.
2. Plugin SanDisk to Computer.
3. System will open new drive in "My Computer" name as Sansa e250 .
4. Copy music,movies and past it into Sansa Drive.
There is another good feature in SanDisk.
You can also record the song from FM Radio.
At the time of listining song from FM press Rec button. Song will get saved in your SanDisk.
Thanks,
Vaquar
Sansa e250
Make a copy of one of the files, and try changing the extension to .mp3.
Downloading music
how do you download music onto a sansa sandisk?? I tried using itunes but it wouldnt work.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
