WHY DOESN'T YOUR MANUAL TELL YOU TO REPLUG THE COFFEE MAKER WHEN ADJUSTING THE AMOUNT? THE 1ST THINGS IT READS IS UNPLUG THEN LOOK AT THE SET BUTTON THEN HIT THE START BUTTON TO ADJUST AND LISTEN FOR THE CLICKS BUT IT NEVER MENTIONS REPLUG FIRST - SPENT 2 DAYS ON THIS BEFORE I FIGURED IT OUT - HOW CRAZY.
You have to wait for it to go through the reheat cycle. If it is not going through that contact Keurig and they will walk you through some test steps to see if it is malfunctioning.
just plug it out from the wall current for about half day so that the coffee maker can reset itself then plug it in back.if that does not work that means the timing transistor is faulty.you will have to have it repaired.good luck.
Hi
Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don’t release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button.
If that doesn’t fix it, then you might need a new flow meter.
Setting and Adjusting the Clock • The machine must be “off“. • Press and hold the prog button (o) for 3 seconds: the hours will blink “88 _ _“. • Adjust the hours in steps by pressing the h/min button (n). • Press the prog button : the minutes will blink“ XX 88“. • Adjust the minutes in steps by pressing the h/min button. • Confirm the setting by pressing the prog button.
