Question about Frigidaire Kitchen Ranges
We have a digital display on our Frigidaire stove it is not working and nor is the oven. The elements are fine. Any suggestions please?
Posted by patriciab826 on
Ginko
  • Frigidaire Master
  • 19,396 Answers
Hi.
A technician should read voltage to the electronic oven control board, to test the EOC in full. For safety reasons testing hot wires is an operation that must be done by a repairman.
If there is no power to electronic control, then the wiring harness must be replaced.
If the oven control display is blank I would exclude that the problem is being caused by faulty element, faulty temperature probe, or defective door latch, all this faults do not cause the display and controls being non-responsive.
Most ovens have display, control board and pads as separate parts, in that case the connectors between parts in the control assembly must be tested.
Parts and diagrams for most models are available here.
Regards.
Ginko.
Posted on Mar 02, 2010
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Dec 01, 2015 | Kitchen Ranges
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven
Yes, that sounds like a relay on the oven control board. Here is the part to order that has a 365 day, any part, any reason return policy so you may want to order from them.
Jun 25, 2013 | Ovens
We have a Frigidaire electronic ignition range about a decade old. The stove works fine. But lately we've noticed if we're using any stove elements the oven won't ignite and heat up. Conve
Sounds like the pressure regulator on the stove is going bad. The pressure regulator is located in the back. Your gas supply line should connect directly to it.
Dec 23, 2012 | Kitchen Ranges
Need heating element for oven of 1950's Frigidaire by GM stove
Fixya is unable to identify parts sources.
Jan 23, 2018 | Ovens
I have a frigidaire oven, my wife touched the oven element with an oven mitt and blew out the main 100 amp house breaker. the oven does not work anymore but the burners are fine. should i buy a new element...
THE ELEMENT SOUNDS LIKE IT IS SHORTED BIG TIME TO TRIP 100 AMP BREAKER. I CAN'T SEE WHY A ELEMENT BEING TOUCHED WOULD DO THAT. CHECK THE WIREING TO THE ELEMENT AND MAKE SURE NOTHING ELSE HAS SHORTED TO ALSO CAUSE THIS PROBLEM, PLEASE TURN THE POWER OFF FIRST. BUT THE ELEMENT CAN BE REPLACED AND NOT THE WHOLE STOVE
Aug 28, 2009 | Frigidaire Ovens
Gas stove works, but oven does not
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Jul 30, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire Electric Slide-in Range - Oven Flash
Richard, sounds like you did all the pretests. You'll need a new display panel. When you work on it, be sure to cut the power.
Dec 13, 2007 | Frigidaire FES367 Electric Kitchen Range
Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Oct 27, 2007 | Frigidaire FEF366DC Electric Kitchen Range
Kitchen Ranges Logo
340 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
