Question about GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer
I was just given a ge chest freezer model # cb10 dk serial number vv186793. i cleaned it up and plugged it in about 5 minutes later it started buzzing . i turned the control to the lowest setting (0). and the buzzing stopped. there is a switch that says off test and on . i tried all setting but the buzzing continues..anybody know what is going on? and how can i fix it
Posted by roxiebaby on
geoff hunter
  • 4,793 Answers
Switch on and leave it to freeze.approx 24hours.buzzing could be compressor working overtime to get cold.or in fact the freezer is not on a level surface.
Posted on Mar 03, 2010
Lid on chest freezer will not securely close Model #FCM 7DAA WH Serial #RTI63278 Mfg 81998
Remove lid, squeeze hinge back into shape and refit, adjusting screws in rear of hinge bracket as you do.
May 19, 2012 | GE Freezers
Power off for electrical repair. Plugged floor freezer back in and a loud buzzing noise is ongoing. Not sure if this is a temperature alert or if there is another problem. Thanks for your help.
This sounds as if its a start relay problem. They are attached to the compressor
You will need the model and serial number to get a new one at the appliance
parts store. They are usually under a plastic cover on the side of the compressor
and the cover is retained by a metal spring clip. Remember to unplug unit before
replacing this part. The model and serial number should be located near the compressor.
May 04, 2011 | GE Freezer  14.8 Cu. Ft. Manual...
BUZZES
This sounds like the temperature monitor is alarming because the temperature has not cooled down enough yet in your freezer. turn the monitor off until the freezer reaches proper temperature then you can turn it back on.
Jul 20, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
I have a chest freezer model AFFC1526DW2 it stopped freezing. The power light is still on. What could be the problem
the thermostat may not be turning on the compressor.
Do you hear a buzz and or clicking every few minutes when plugged in? If so the compressor is trying to start indicating a problem with the compressor. you could check the windings for continuity or a short and then try a 3-in-1 start kit.
May 05, 2010 | Frigidaire Freezer FFU1724
GE 5CF CHEST FREEZER
I got delivery today for the same freezer and had the same question.
I just called GE's customer service number (800-626-2005) and the agent told me that GE uses this button panel (which has the green on/off light switch, the two white switches, and the round control dial) for all or most of its freezers. But the buttons do not do anything on the 5 cubic foot chest freezer. They are not connected to anything and are non-active buttons. On other freezer models above this one, the two switches serve a purpose, but not the 5CF model. This is a simple, inexpensive freezer and it doesn't have bells and whistles--but it does have the same control panel as the multi-feature freezers. Hope that helps.
Sep 05, 2009 | GE 5 cu. ft. / 142 liter Chest Freezer...
Outside of chest freezer gets hot
it is normal for outside to get hot. that is where the condensor coils are located. if unit is working don't worry.
Jul 26, 2009 | GE Freezers
We purchased an 8.8cu.ft. Kenmore chest freezer model # 970-159320. I plugged it in at 10:00 am today and later transferred food from old freezer. When I go home at 10:00 pm this evening, the compressor...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 11, 2009 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Brand new unit, compressor noise.
Since I could get no one to tell me about new freezer compressor making buzzing noise while on, I had the store come a pick it up and give me my money back.
Apr 28, 2009 | Frigidaire 12.8 cu. ft. Chest Freezer...
GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer Logo
550 people viewed this question
Top GE Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a GE Freezer Expert? Answer questions, earn points and help others
