Question about Kirby G6 Bagged Upright Vacuum
I need to know how to put my belt back on my kirby 2000 G6 vacuum belt
Posted by jenniferc361 on
Chris Jones
  • 438 Answers
Greetings from GoVacuum,
Here's a very informative video that we've recorded explaining in detail how to correctly install the belt on your Kirby Generation vacuum cleaner. I hope this will help you.
Kirby Belt Change Video;
If this video was helpful, please be sure to rate this Solution by clicking on the 4 Thumbs Up icons in the top right hand corner of the page. If you have any questions, please feel free to email me, I'm more then happy to answer any questions you may have.
Chris Jones
GoVacuum.com
Posted on Mar 19, 2010
Changing belt
here is a video how to change belt on kirby vac
Feb 27, 2013 | Kirby G6 Bagged Upright Vacuum
I need to put a belt on..i have the head off, and have the knob on the front in the belt off postion, but where does the belt even go?
Greetings,
We have made a video demonstration for this particular repair. Changing the belt on the Kirby is never fun, but this easy to understand video should help you out and make it easier for you.
Here's our video repair of how to replace the belt on your Kirby G6:
I really hope that this video was able to help you put the belt and the head of the vacuum back on. It's a handy video to have when it's time to change the belt. If this was helpful, kindly rate the video as helpful by clicking the Thumbs Up icon in the lower right hand corner below.
Feel free to write a repair clarification if you have any further quesitons.
Thanks again,
Chris J.
Mar 10, 2010 | Kirby G6 Bagged Upright Vacuum
Kirby g6 will not pic up dirt. Belt is on and bag
check for blockage or impeller if vacum makes loud noise the impeller is the part that gives it suction
Oct 15, 2009 | Kirby G6 Bagged Upright Vacuum
Manual please or help
Below is a link to GoodVac.com. They have a Kirby G6 Manual for $9.30. Although it is labeled for the G6, it is applicable to models G3 through the Sentria. ("G" = Generation)
http://www.goodvac.com/Kirby_Gsix_manual_p/k-sup-mnl-260099.htm
Also on this page is a weblink to their "Online Kirby Vacuum Manual". It will explain how to replace the roller brush belt.
Jul 17, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Dont know how to put the shampoo system together on my kirby g6..
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Copy and paste the above link to the address window of your browser for the Kirby Shampooer instructions.
Hope this helps :)
And thank you for using Fixya!!!
May 02, 2009 | Kirby G6 Bagged Upright Vacuum
I need to replace the belt on my kirby g6 2000 how do i do it
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=688060
Generic problem for all Vacuums
Posted by shawn81 on Jun 20, 2008
I need to replace the belt on my Kirby g6 2000 how do I do it
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Kirby has a belt hook on the inside of the bell housing and 1st you need to release the old belt by turning the dial in front of the bell housing counter clock wise to get the old belt off. Some Kirby vacuums the entire bell housing comes off and makes it fairly simple but the process and the format to change the belt is the same. The brushroll has screws on each end and the screw heads need to be facing down on each side, so remove of drop down one side of the brush and slide the belt onto the middle of the brushroll then re-insert the brushroll, screws head facing down, then use the Kirby dial to hook the belt and then dial the belt onto the Kirby fan pulley and then you should be done. If you have further questions please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 20, 2008 | Vacuums
Replacing brush roller on my KIrby g6 limited edition
You need a new belt. When the green light goes out, that means your brushroll has stopped spinning. Here's how to change it....
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Even if you just replaced the belt, this guide will help you make sure that you got the brushroll back in the right way.
Hope it helps....
Marci
Dec 08, 2007 | Kirby G6 Bagged Upright Vacuum
Kirby G6 drive mode
look under the vacume cleaner and take off the cover make, shure the belt is where it needs to be, you should have a setting on the vacume cleaner that gives you an addjustment for the carpet your on, raze it up.
Nov 26, 2007 | Kirby G6 Bagged Upright Vacuum
Changing a belt on kirby G6
I have written an online guide to help with this issue. Click on the link to view the guide.
Hope this helps...
Marci
Oct 15, 2007 | Kirby G6 Bagged Upright Vacuum
Kirby G6 Bagged Upright Vacuum Logo
470 people viewed this question
Top Kirby Vacuums Experts
Paul Bade
Marvin
Marvin
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
