SOURCE: Ascaso, Innova, Dream Heater not working
If you are confident that your heating element is dead and are filling adventurous enough to replace it- you can get one at:
http://www.1st-line.net/cgi-bin/category.cgi?category=review&item=i365&type=store
I saved myself shipping and repair costs by having it replaced by a friend. He took pictures and marked wires & connectors before removing the broken heater.
Yeah,, this looks to be systematic failure with this machine. Very disappointing- for this kind of money, one would expect the machine to work a bit longer after warranty expires.
SOURCE: I think the pump is going out on my Ascaso Dream
Hi Pumps are easy to replace in your machine. there is one that will work in your machine on ebay.
SOURCE: Acaso Dream espresso machine no crema
Are you getting enough atmospheric bars of pressure? Should be around 9 or so. if not that may be your problem... also if your portafilter is pressurized (there will be a plastic disc under the screen) try removing it and see if you are getting crema then... Helped alot with mine. I also shaved the bottom to make it bottomless but that may be alot further than you want to go.
SOURCE: My ascaso epresso machine does not heat water, I
We do not advise you attempt to install a new heating element in this machine. It is extremely meticulous work involving many small parts, you will need metric tools, meters, etc, it requires removing the old boiler, disassemble it, purchasing a new one with the correct gaskets and moving over all the sensors to the new boiler. We do this repair and even for us it is somewhat hairy.
www.dolcevitaespresso.com
