Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
My dell dimension 5150 won't boot up , Screen stays dead Please advise what motherboard would be best
Posted by chris_foley on
  • lamajciredor May 11, 2010
    what do you mean won't boot up? please check if the led indicators are on. if the screen is still stays dead maybe you need to install a new video card.
  • joecoolvette
    joecoolvette May 11, 2010
    Why has your diagnoses led straight to the motherboard? Would like to know what you base your diagnoses on, and if you have tested the power supply.
Abraham Jacomina
    New Friend:
  • 113 Answers
Check the lights at teh front of the computer. the numbers 1234 are the indicator lights. if the lights are 1 and 4 then thats a hight probability taht motehr board is dead. if not you may try reseating some parts in the computer like the memory cards, video card, modem, hard drive and optical drive. try to reseat power connectors also.
Posted on Mar 08, 2010
IQUIT
  • 3,940 Answers
Dell chassis cannot accept a Non-Dell Motherboard with out modification. Generally simpler to use a Dell branded motherboard. You can get one here: http://shop.ebay.com/i.html?_nkw=dimension+5150+motherboard+&_cqr=true&_nkwusc=dimension+5150+motherbaord&_rdc=1
Posted on Mar 07, 2010
Dell dimension 5150 wont boot past post. I've tried afew things but nothing works. can you help? thanks
If it won't go past POST then there is a hardware error. Try removing the hard drive and RAM. The mother board should complain at power on giving messages. If it does, try fitting the RAM module by module, then the hard drive.
Apr 17, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I have a dell dimension 5150 and when i switch on i have a white screen and can go no further?
Do you get any beeps? Search POST - power on self tests. In my experience I fear you might have a motherboard failure.
Apr 15, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Only amber light is on when start...no green lights...
its a power problem. Your power supply is not giving enough power
Dec 08, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 will not start!
This is related to Hardware.
There might be a lose Ram of data cable connection on Motherboard.
This type of issue is also seen when the there is dust accumulation on Process Fan and CPU fan resulting in over heating.
This might also be due to malfunction of a motherboard.
The third reason could be that SMPS his not working.
Nov 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 Boot Problems!
You can probably try two things here.
1) Go to the BIOS and reset the defaults.
2) Clear NVRAM from your Dell computer. Here is how you do it.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&docid=4C1BF720A3E78F92E040A68F5A2811BE&journalid=7788D9829DCAA7C8E040AE0AB6E12FA2&Query=bnZyYW0=&SystemID=DIMENSION+5150/E510&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false
Dell dimension 5150 boot up difficulties - just goes to the Dell screen and then nothing - a little blinking white dash in the upper left corner. I usually hit f12 to boot from there, but it seems that...
try to run diags, press f12 when booting the choose utility partiton. check for any error on your HDD but it seems like its an OS issue so all you need to do is to uninstall and reinstall your OS
Sep 26, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
PC was rebooting itself. I tried vacuuming out dust from inside box. Now it won't boot up at all. Numbers on front panel 3 & 4 stay lit and monitor only shows scrambled colours PC is a DELL Dimension...
Try manual cleaning the graphics card and the RAM by removing from the slot and rub the pins with pencil eraser as shown in the images.
And re-attach them to the motherboard, also clean the graphics card's fan with small paint brush. Works for me, hope same goes with you.
Sep 24, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Bios
Are you sure you downloaded and installed the correct BIOS patch? If you installed the wrong one, it will cause it to stop.
Jul 23, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Restore my dell dimension 5150
disable all integrated devices, change boot sequence to cd drive & then try to reinstall....
Jul 03, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Change Motherboard For Dell Dimension 5150
If you replace with the same motherboard that's in already, that would be easiest for you.
But if you use a different one, you'll have to re-activate Windows, and download and install new device drivers.
Jan 09, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
539 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
