https://www.manualslib.com/manual/575481/Fisher-And-Paykel-Dishdrawer-Dd603.html?page=22#manual this link takes you to the service manual for your machine, there will be details on manually testing individual components, you should be able to operate the pump and check that it is performing as it should, page 39 describes the process to lift out the rotor, do that and check the rotor impeller, this is the drain pump, if the rotor vanes are broken you will need to replace it,
Hi Dishwasher not pumping issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please check the parts manual for your dishwasher, check the drain pump & drain filter's location from the link---
Fisher and Paykel Dishwasher DD603 Parts Manual Please note that dishwashers don’t pump out the complete water such that heating element doesn’t overheat. Please post back for any further assistance. Daniel
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
