Acer 15.6'' Aspire AS5335-2238 Laptop PC w/ Intel Celeron Mobile Processor 585  PC Notebook Logo
Posted on Mar 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen sometimes lights up but mostly stays dim
Screen sometimes lights up but mostly stays extremely dim so i have to use an external monitor, i was wondering where the lid close switch is on my acer aspire
electronic & computer repair& servicre
Level 3:
  • Acer Master 12,061 Answers
  • Posted on Mar 02, 2010
Acer Master
Level 3:
Answers
12061
Questions
0
Helped
4008133
Points
36390
You have a bad connection on the LCD ribbon, or a cracked LCD ribbon, or the Inverter is intermittently faulting, the backlight/circuit is faulting. It is hardly ever the switch....but it is under the end of the screen look for a tiny black stick.
MY N5030 LAP LCD IS IN LAW LIGHT.CAN AS A SHADOW. I CONECTED TO EXTERNAL MONITOR IT WORKING BUT LAP DISPLY STILL AS
look khal sometimes most netbooks have a "hotkey" sequence to dim or brighten the screen on mine its Fn/F4 or Fn/F3 try this first or goto you manufacturers site and find the exact sequence of "Hotkeys" [remember Fn/F5 toggles between screen and monitor]!!
Good luck
Davey snake!
My acer aspire 6530 boots up fine but I get nothing on my screen. It's just black, no light at all. When I plug it into an external monitor it works fine and in fact I'm using the acer right now but with...
To check whether the LCD screen itself if the issue or the backlight or inverter. You have to carefully look in the screen and see if you see anything on it. It would be extremely dim but try white background and black screen. If you see something in it, then most probably it's either the backlight or the inverter. For that you need to buy those from the market and install it, OR IF YOU ARE NOT A TECH GENIUS I WOULD RECOMMEND YOU TAKE IT TO A DEALER IF ITS IN WARRANTY TAKE IT TO ACER THEY SHOULD FIX IT FOR FREE.(I dont know the rules of Acer, but most companies fix that for free)
Toshiba screen is blank ans light on under F10 key.
Is the screen completely blank, or just dim? If it is dim, then most likely your lcd power inverter is bad, and needs to be replaced, which is the cheapest part to replace. If it is completely blank then you should try to hook up an external monitor to the laptop, and don't get any video, then most likely there is an issue with your motherboard or video card. The external monitor method sometimes needs you to press a combination of the Fn key and another F key in order to switch from your laptop lcd to an external monitor.
3helpful
2answers
When I turn on my computer, the screen stays black
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Screen flickering when turning on laptop and sometimes the laptop turns on after flickering and sometimes doesn't turn on at all after flickering. Just stays black.
You may have a faulty inverter or loose power inverter connection. OR
Check out
www.lcdparts.net
1helpful
2answers
The screen on my Compaq Evo N610c is dim
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
1helpful
HP pavilion notebook screen turns black after flickering
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
2helpful
Dim display ... no backlight
2helpful
Lcd screen black on laptop. External monitor works.
Defective CCFL backlight may has the following symptom:
  • Picture flickering with dim display.
Video problem
Generally this type of problem is the video card, however, it's extremely rare, but sometimes a screen malfunction will override the video out causing the appearance of a bad card. To check this, disconnect the screen, and try the external monitor. If the external works properly, then it's the screen.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
