Question about Nikon D40 Digital Camera
Slow sync flash - nikon d40
Other than using the night portrait mode on my nikon d40, how do i take front/rear curtain shots? thanks
Posted by cfriesen on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Set the exposure mode to Manual (M) or Shutter-priority (S) and specify the shutter speed yourself. You'll have to set it sufficiently slow in order to see any difference between front- and rear-curtain.
Posted on Mar 02, 2010
How do I turn flash on and off?
The multi selector is the round control on the rear of the camera with the OK button in its center.
The flash mode button is the top button on the selector, it has a lightning flash icon.
Press the flash mode button on the multi selector.
Highlight the desired mode and press the center of the multi selector.
The flash modes are:
AUTO; Flash fires automatically when lighting is poor.
AUTO WITH RED-EYE REDUCTION; Reduces "red eye" in portraits.
OFF; Flash will not fire even when lighting is poor.
FILL FLASH; Flash fires whenever picture is taken. Use to "fill-in" (illuminate) shadows and back-lit subjects.
SLOW SYNC; Flash illuminates mainsubject; slow shutter speeds are used to capture background at night or under dim light
The selected flash mode icon appears at the top of the monitor.
Oct 22, 2014 | Nikon COOLPIX L3 Digital Camera
Nikon D40. How do i force the flash to work in daylight?
First, you have to be in one of the PSAM modes; in the other modes the camera decides whether it needs the flash and in daylight it will decide there's enough light without it. So, after turning the model dial to one of the PSAM positions, press the flash button on the front of the camera to pop up the flash. In these modes the camera will fire the flash if it's popped up, and not if it's down.
To change the flash mode, hold down the flash button (after it's popped up) and turn the command dial. Depending on the chosen exposure mode, your choices may include Fill flash, Red-eye reduction, Rear-curtain sync, Slow sync, Rear-curtain plus red-eye reduction, and Rear-curtain plus slow sync. Refer to the "Flash Mode" section of the manual for full details.
Jul 30, 2011 | Nikon D40x Digital Camera
How do I use the rear curtain sync on my d90
Hi You might need this information. I could write but online informations are very helpful and save time. http://www.digital-photography-school.com/slow-sync-flash
thanks and best regard!
May 25, 2011 | Nikon Cameras
REAR FLASH PRB ON NIKON D300
If your doing what I think you are then, It sounds like the flash is set too act as a commander for the off-camera CLS flash setup. Check setting e3 and put it in TTL mode. It's called rear or 2nd curtain flash sync.
Oct 21, 2009 | Nikon D300 Digital Camera
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Nikon D90 rear curtain sync will shoot flash twice
    That is most likely the TTL preflash and should not show up in your final exposure.
    Try setting the flash control to manual (e2 under the Bracketing/Flash menu). That should give you only the one flash at the end.
    Aaron Gum
    Mar 06, 2009 | Nikon D90 Digital Camera with 18-105mm...
    Nikon D40 shutter speed problem
    The D40 will not take great photos of an indoor event without blurring or noise. You need a fast lens and a high ISO using the popup flash or on camera flash would be ideal but some of these events you can not use flash. All these images I shot with a Nikon D40. http://www.facebook.com/home.php?src=fftb#/pages/Keller-TX/Raving-Design/78762448229?v=photos&ref=ts Learn to use the camera for ur events. Experiment it's all about trial and error. Ray
    Dec 20, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
    My flash is too bright...
    Flash also has several modes you can toggle through by pressing and holding the button that pops up the flash while using the command dial to change modes... rear curtain, slow sync, red eye reduction, etc. These show up on the top LCD under the lightning bolt icon.
    Apr 27, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
    Night pictures
    a) Place the camera on a tripod (or a steady surface - e.g. a chair)
    b) Select P mode
    c) Focus and take the shot.
    Most probably, with the above settings, the camera will select a longer exposure without flash, lighting the scene properly (i.e. making it appear as night, as it should be). However, know that this will also create motion blur of moving subjects (the kids, in this case). If you want to avoid this, you must use flash in slow sync mode. Press repeatedly the flash button, until you see the "slow" indication on the screen (where the flash info appears, down left). Again, the camera should be on a steady surface.
    If your pictures are again too bright, it means that the Exposure compensation is for some reason set to +. Use the appropriate button (check the manual if you don't remember which one it is) to fix it
    Dec 18, 2007 | Nikon D40 Digital Camera with G-II 18-55mm...
    Nikon d80 continuous mode
    This can be that the flash sync speed of the camera is not correct. There may not be enough exposure from the flash to the subject during the opened curtain (shutter) sequence.
    Jerry G.
    Nov 29, 2007 | Nikon Speedlight SB-600 TTL Flash
    Nikon D40 Digital Camera Logo
    237 people viewed this question
    Top Nikon Cameras Experts
    Ric Donato
    Ekse
    Muntejaya Ginting
    Muntejaya Ginting
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
