Question about Sony FD Trinitron WEGA KV-27HS420 27" TV
What channel or setting(s)must I select to play a DVD from my DVD player onto the TV? It worked before, but I forgot how.(I lost my manual.) (Sony Trinitron KV-27HS420)
Posted by dasein627 on
paul proctor
  • 4,102 Answers
Hi make sure the dvd player is switched on the on then make sure the leads are fitted correctly from the dvd player to the telly then get the telly remote and find the av button or the source button or a button with a small picture of a rectangle with an arrow running from left to right once you have found this button press it once then wait about 10 sec if you cant see the picture from the dvd press it again it all depends on how many inputs the telly has to how many times you may need to press it, if after doing this it still dont work then double check the leads and try again.
let me know how you get on or if you need further assistance ok
Posted on Mar 01, 2010
I had DVD player hooked up to watch movies, I was trying to set a universal remote because I do not have one already. When I couldn't get the remote to work I pushed Menu on the front of the tv, chose...
Perhaps your dvd player output is set for channel 3 so you have to select that channel for the dvd player to play on your tv. Some older analog tvs have a separate input for dvd on the back or front. In that case you have to select that setting from the tv menu
Sep 17, 2013 | Televison & Video
Lost manual need help setting dvd home theater to play with tv. will play dvd in theater but not tv
THIER IS A VIDIEO OUT NEXT TO THE COMPONTENT GENERALY THIER MAY NOT BE AN AUDIO OUT PUT SINCE THE SOUD COMES FROM THE BUILT IN AMP HOOKING UP TP THIS WILL LET ALL DEVICES BE DISPLAYED ON THE TV ONCE THE PROPER INPUT CHANNEL HAS BEEN SELECTED THEN YOU WILL ONLY HAVE TO SELECT THE AV ON THE SURROUND SOUND SYTM TO SWITHCH IVIDOE AND SOUND FOR EACH DEVICE PLUGGED INTO THE SYTEM
Nov 20, 2009 | Oritron DAV3101 PROGRESSIVE SCAN DVD
What channel do I set my TV to in order to play a DVDdisc?
Assuming your DVD player is properly connected to the video and audio inputs of the TV, you should be able to press the "input select" button on the remote and toggle between TV and DVD. A copy of your manual is here: http://www.emersonaudiovideo.com/pdf/manual/CR202EM9.pdf
Oct 14, 2009 | Emerson CR202EM9 TV
DVD Player Only Produces Snow After Power Outage. Halp!
Sounds like your TV has lost the DVD channel. Turn off TV and make sure the DVD player is connected to TV and is playing a DVD. Now put you TV on and press the SOURCE or AV button on your TV remote until you can see the DVD channel. In older TVs you may need select channel and tune it manually using the TV setup.
Jul 10, 2009 | Insignia Digital-to-Analog Converter for...
Emerson VCR/DVD player - can't get tv (cable tv) to play anymore
I have the same problem with my Emerson VCR. When the ADD button is flashing, just press the menu button to exit the menu. It will add. That's the only thing I know to do. Sometimes it works, sometimes it doesn't.
Feb 01, 2009 | Emerson EWD2203 DVD Player/VCR
Trying to hookup and play standard DVD player
Yellow is video and red&white audio ,so when you hook up dvd does picture preview of dvd come on?You may have to switch to aux for dvd or different channel try checking each channel .
Dec 12, 2008 | RCA F25441 25" TV
Video channel
if your DVD player supports a HDMI cable a single cable is enough for both audio and video channel.
but both your player and TV must support HDMI.
Aug 12, 2008 | Samsung DVD-V4600 DVD Player/VCR
Sony SLV-D350P DVD/Video cassette Player
I have the manual. Are you trying to record something live? if so:
1) Turn on both the DVD/VCR and your TV.
2) Switch the input selector on your TV so that the signal from the player appears on the TV screen (this is usually something like 'input 1' or 'line 1' and so forth)
3) On your remote, set TV/DVD-VIDEO to DVD-Video, then press SELECT VIDEO to control the VCR. These buttons are at the upper left hand corner of the remote controller.
4) To record from a cable box, turn it on.
5) make sure the tape is longer than the total recording time.
6) insert a tape into the VCR.
7) press CH +/- on the remote to select the channel or line input video source to record.
8) select the tape speed SP/EP (SP provides better quality, EP provides three times the recording time as SP)
9) Press the record button to start recording. The VCR display will display the message REC.
Nov 25, 2007 | Sony SLV-D350P DVD Player/VCR
Setting up the chanel on the VCR
(FROM MANUAL)
RF Output Channel
1-Set TV to Channel 4
2-Insert a prerecoeded tape into the unit
3-Press Source until VCR light is lit
~ if noise is seen on TV screen, press (VCR/TV) on remote
4-Press play> once
5- After a few seconds, press and hold {Play>} on the unit for 3 seconds
~ The RF output channel will change to channel 4 from 3 and you will see a playback picture
~ When a picture does not appear on the TV screen, repeat step 4
6- Press (STOP) to stop plasyback
Sep 02, 2007 | Philips MWD2206 DVD Player/VCR
Sony FD Trinitron WEGA KV-27HS420 27" TV Logo
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
