Question about Amtrol ST-12-C THERM-X-TROL ASME Expansion Tank, 5 Gallon
Amtrol wh7p My basement flooded and I am trying to reset my amtrol wh7p oil hot water heater. please help . the furnace works but the hot water heater will not . i cant figure out how to reset it? When i turn furnace off and on the hot water heater comes on for a few seconds then goes off. do i just need to reset it? could therebe another issue? i am not even certain the water reached it as it was very low and i have seen it flood more and not impact hot water heater.
Posted by bdjc2001 on
5 Related Answers
freetek
Steve Allison
  • 5569 Answers
SOURCE: not enough hot water. I have an Amtrol Extrol coil water heater
Since you mentioned 'both temperatures' it seems your unit is like most all of them, a lower and upper coil.
If your hot water supply runs out quickly, this normally means that the lower coil has failed. Since heat rises, the upper coil will never supply a tankful of hot water, just hot to start, and then as the flow continues, it doesn't have time to do more than warm the water flowing into the tank.
Every home should now own a simple digital multimeter; they cost less than $20 US everywhere and one can find them in auto parts stores, electronic supply companies and tool companies.
If you have a Harbor Freight tool store in your area, you can get them for under $10 US any time and sometimes even less:
Digital meter
You need to be absolutely certain that the voltage to the water heater is shut down. Before you measure anything else, set the meter to its highest AC setting and check across the coils and then from either contact to the metal housing. If it is dead everywhere, then set the meter to the lowest Ohms scale (normally 200). The resistance of the coil should be nearly the same reading as when you simply short the meter's probe tips together. If it measures 'OL' then the coil is open and must be replaced.
Posted on Feb 26, 2009
Keith Fournier
  • 308 Answers
SOURCE: Amtrol Boiler Mate WH-7P (oil).
If you check for power at the tank, (the black and white wires) you should read voltage, either 24 vac, or 120 vac, depending on how it is wired. If there is no power there, then you will have to chase power back to where you do have it. There is no fuse or reset button on this model.
Posted on Jan 19, 2010
SOURCE: I have a 23 yr. old Amtrol WH7P that has sent
Hello 23+yrs is execptional service! Yes it is leaking into the boiler.Time to shop for a new indirect hot water heater.Forget a coil.Thanks
Posted on Apr 01, 2010
Testimonial: "Thanks for advice, my hard, low ph well water finally caused a pinhole in the coil. Thanks for supporting my theory."
Anonymous
SOURCE: ER3 no hot water
Er3 means that the water is being heated for more than 1 hour without reaching the set temperature.
Need new aquastat.
Posted on Dec 28, 2010
Jack Spooner
  • 1015 Answers
SOURCE: HELP... my flush line from
I can understand your wanting to not waste money but in thirty years in business I always said If a piece of equipment had been flooded then be safe and replace it. I know it's easy for me to spend other peoples money but that is what I would do. Best of luck and thank you.
Posted on Mar 07, 2011
AMTROL WH7P-41 GAL TANK. 12 YRS OLD. BOILER PRESSURE IS INCREASING ABOVE 30PSI, AND DUMPING SMALL AMOUTS OF WATER FROM RELIEF VALVE ON BOILER. Do I replace coil?, or buy a new tank? Thank you
do you have a pressure tank as part of your water heater and water pipes? if yes, check to make sure tank pressure matches your incoming water pressure from your municipal hook up
Aug 18, 2015 | Amtrol Water Heaters
ER3 error code on amtrol hot water tank
Simply means hot water heater called for heat for 1 hour and never rose in temperature or reach stepping, unit automatically goes into lockout. I would reset power
Feb 14, 2015 | Amtrol WHS-80Z - WHS-80Z 80Gal Hot Wtr...
Amtrol wh7p
replace, that means inside tank is leaking. leak is not on lines correct?
Jan 24, 2014 | Water Heaters
Heater broke, my Amtrol water heater expansion 80 gal tank, takes hot water from the oil fired furnace, and keeps it hot, However, the tank is set at 140 degrees, but the water coming out if the hot wter...
Hiliary
sounds like the primary coil in side is cracked and is mixing hot water.. with the cold water in tank need to check and replace as necessary
Sep 15, 2013 | Amtrol Water Heaters
Wh 9L amtrol water heater..the water temp is too hot.. the heater is 10 yrs old is it possible to remove the temp probe and clean?
Amdrol makes indirect-fired water heater that gets heat from a boiler
http://www.amtrol.com/boilermate.htm
1) Pdf manual on amdrol website show a mixing valve that mixes cold water with the hot water so water temperature going to faucet stays the same:
http://www.amtrol.com/pdf/MC10169%20BMconstantempflyer.pdf
You set the temperature of the mixing valve.
You can also set up 2 sets of pipes ... one is connected to mixing valve that goes to sinks and tubs. The other pipe bypasses mixing valve sends hotter water to washing machine.
2) The manual for Amdrol:
http://www.amtrol.com/pdf/9040-586%2001_09%20BoilerMate%20Indirect%20IO.pdf
The new models has a temperature sensor that plugs into digital readout.
This is a thermistor sensor wire that can be ordered as repair part
3) Amdrol has e-mail address:
[email protected]
4) You can post your question on a water heater forum
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Nov 11, 2010 | Amtrol Water Heaters
Amtrol water heater WH-7P gets barely warm water
From what you are saying it sounds like an issue with either a circulator pump or a zone valve. It depends on what type of system you have ... if you have a circulator pump that only runs the Amtrol then that is probably bad. If you have a zone valve system then it is probably the zone valve if you still have heat for the rest of the house. If you have no space heating then it is probably the circulator pump.
Nov 04, 2009 | Water Heaters
No hot water from the Amtrol Boiler Mate model wh7p
The smart control was only reading 140 it never went up or down from that number and now it has an ER3 code seem the circulator just runs and runs
Mar 09, 2009 | Water Heaters
Amtrol ST-12-C THERM-X-TROL ASME Expansion Tank, 5 Gallon  Logo
356 people viewed this question
Top Amtrol Water Heaters Experts
Bill Johnson
Marvin
Marvin
Paul Carew
Are you an Amtrol Water Heater Expert? Answer questions, earn points and help others
