the evacuation pump is either blocked up
or not running
i would remove the blockages
then run through an empty load cycle of 95deg white wash and some calgon tablets
This video will show you how to open your Zanussi Progress ZWG3121washing machine
door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
The door does not open because there is water inside the machine. To open the door you need to empty the tub first.
To empty the tub disconnect power, open the door at the bottom of the machine's front side, unscrew the drain filter cap and collect water using a container.
Usually that is enough to allow the door to open. If the door does not get released, try running a cycle again.
If still no luck, then the door is locked either because the pressure switch detecting water level is clogged with soap or because the power surge has damaged some component. In that case the machine must be partially disassembled to reach the back of the door opening mechanism. The door latch is reachable either from drain filter access or from top of the appliance.
Emptying water through the drain filter and/or restarting a cycle usually is enough to release the door lock.
loose drum sounds like drum bearing Faulty ..Most models sold as spider kit in cludes bearings and spider assembly, if its more than 5 yrs old then perhaps not worhtwhile due to cost of parts here in u/k parts approx £80 =+ Labour..hope this helps you
Sounds like you have a clogged tube.Try cleaning out the dispenser,pour hot water into it then run threw a cycle empty setting on hot this may clear it out.
Hope this helped.Please rate me For more help go to live chat. lenwest
almost certainly the door interlock faulty. fairly cheap part and easy to replace.
remove plastic clamp holding door boot to cabinet and peel back in the area of the door interlock. door lock is held in by 2 screws from outside which undo and withdraw lock. disconect electrical plug and small diameter tube at bottom. fitting new one is just the reverse
Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
