Question about Samsung Propel A767 Cell Phone
My memory card will not stay in. shoots back out
Posted by bd81098 on
Anonymous
  • 713 Answers
Hi, i think the problem you are encountering is due to a non-compatible memory card been used or the memory card is not properly inserted. Try and consult the manual of the phone to see the type of memory card that you are suppose to use and the way it should be inserted.
Take care
Posted on Mar 01, 2010
Anonymous
    New Friend:
  • 56 Answers
Make sure that you have the right orientation.
you may have to push a little harder since it is spring loaded. it needs to be pushed deeply in order to be latched in.
Ge X550 will not switch to memory card when it is installed, stays on internal memory
Hi, a few possibilities...you may have a menu setting that only saves to internal memory, so: clear your custom menus and check your shooting and playback settings. The specs on your camera states that it supports up to 16GB card, so the problem should be a menu setting. Also make sure the little tab on the left side of the SD card is NOT in the lock position.
D80 High Speed Continuous Shooting Doesn't Work
I assume that your camera will shoot in continuous mode, but only slowly. The two main reason for this is memory buffer overload due to your memory card not being able to accept data quickly enough or insufficient battery power. When you have a slow memory card, the buffer circuit in your camera retains data until the card accepts it, but if so much data comes in so quickly that it exceeds the buffer's capacity, the camera will slow down until enough buffer space becomes available to accept more data. For example, when I first got my D90 (I use a D800 now), I tried to take video and the picture and sound would not stay in sync. with the 35 Mbs cards that were the fastest available at that time. When Sandisk developed a 45 Mbs card, I no longer had the problem. High speed cards are now available at 60 Mbs, 90 Mbs 120 Mbs and faster and those speeds will allow data to transfer from your camera's buffer so quickly that the buffer will never fill up and your camera will not slow down.
Iam using external 8 GB SD Memory Card.If iam going shoot anything it will shoot around 2 mins 0r 4mins only.It will not shoot continuously atleast 1/2 an hour or more and sudenly it will stop Iam very...
If you are shooting video the flash memory card type is important. It needs to have high sustainable write speeds. You usually want a SDXC Class 10 card for this purpose.
3answers
My fuji finepix s1730 will only 3 photos before freezing. it won't even turn off, unless i leave it for a few mintues. the photos won't save it just says read error when i try looking at photos i've...
Most likely you are experiencing an issue with your memory card. Remove this first then try shooting pictures to the internal memory of the camera. If all is well then reformat the memory card either with your PC or replace it into your camera. If this is still a problem check your card with fuji's list of approved memory cards http://www.fujifilm.com/support/digital_cameras/compatibility/
Mar 01, 2011 • Cameras
Took pics with shoot without card setting on
No. This setting simply allows the camera to go through the motions without a memory card, so you can demonstrate it in the shop. The alternative is to lock the camera so as to prevent shooting without a memory card. Either way, no pictures are saved.
1helpful
Disappearing 'Continuous Shooting' option
Try it without the memory card. Some times they cards to have conflicts with the camera.
Sep 28, 2009 • Cameras
Memory card
Does your phone itself have enough memory to store your videos. If so, put the card back into phone, create a folder in the phone memory and transfer the vids from card to phone. When done, put the card back into PC and format it (Quick Format if poss). When done, put it bach in phone and transfer vids back. Now put it in PC, it should read a card which it formatted itself! Ian.
How to clear the internal memory from a finepix F 480
can anyone help me my photos have been saved on to my intenal memory of a finepix480 camera when i go to copy them back on to the card it says no card when the card is already in what can i do to get them back
Memory card
yes, my camera offers that option too. I can either shoot/store the images onto the camera directly OR onto a memory card. And I use the memory card. Generally the camera storage is pretty small. To find the setting, explore the cameras menu. It's there somewhere. Consult your book or do a search online.
Shooting Speed Dropped
You can perform a Low Level Format of a memory card with this camera. Select Low Level Format under the following circumstances: - The continuous shooting speed has dropped. - The read/write speed of a memory card has dropped. If you perform a Low Level Format, the read/write speed of the memory card may recover, or the continuous shooting speed may improve. A Low Level Format may require 2 to 3 minutes with some memory cards.
Samsung Propel A767 Cell Phone Logo
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Tim Whalen
shizznat
Level 1 Expert
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
