Well first of all you can try the below steps -
1. turn off your ps3 with switch at back
2.hold power button
3.(do this while holding pwr button) switch back on the ps3
4. if done correctly the ps3 should make a loud fan noise causing the fans to enhance for awhile, that should clean out anything that could overheat the ps3
Sometimes the red light will be flashing because there is a problem with the connection of the hard drive to the rest of the PS3 or the hard drive itself is broken.
You can usually fix this problem by re-setting the drive. To do this, go to the side of your console and take out the hard drive. Then replace it in exactly the same position. If the red light is still flashing when you turn your PS3 on, you might have to get a new hard drive, or even a new PS3. Please post comments for more help or information..........
Good Luck!!
Thanks
PS3 Red Screen Of
Death Fix
If you are getting the PS3 red screen then you need to fix
this and you can do so with a good repair guide or send it in.
To actually see how to fix the PS3 Red Screen check out the
link below:
Hope this helps?
This way, you'll be able to successfully repair PS3 red screen problems which means that you'll be playing your favourite games again very quickly.
But first, let's start off with some basic tips.
1 - Take out the HDD drive, and place it back into your console again carefully.
2 - Restart you console.
Didn't work? Try out these 2 tips.
1 - Plug out all cables, and plug them back in.
2 - Check for loose cables.
3 - Then restart your console again.
Still didn't help you to fix your problem? Well, then it's obviously that there's something wrong with your console's hardware. To fix it now, there are 2 more options left.
Fix PS3 Red Screen Problems By Either Sony, Or A Repair Shop
What you can do, is that you'll actually ship your troubleshooting console over to Sony, or a repair shop. This way, you'll let them repair your console for you.
However, there's a catch... Is your warranty expired? Then Sony will ask you to pay them $150. Also, a repair shop isn't very cheap either, they'll charge you $100-$200 for the repairs.
Another important thing to keep an eye on is the fact that... It's taking lots of time before the repair and shipping process has been completed. It can take 2-6 weeks before Sony or the repair shop has completed the PS3 red screen repair.
Conclusion: This option is very expensive and time consuming.
Repair PS3 Red Screen Problems By Yourself To Save Your Money And Time
From my experience, repairing a console yourself is the best option in order to save your money and time because you won't have to pay hundreds of dollars and you won't have to wait for weeks either.
However, you do need to know the technical side of repairing a console yourself. If you haven't got that, then you'll still be able to repair your red screen on PS3.
Using A Step by Step PS3 Repair Guide To Easily Fix The PS3 Red Screen Problem
By using a PS3 repair guide. You see, when you use a repair guide, you'll be guided through the exact steps to take. A repair guide will give you a readable guide with detailed photo's, HD videos and personal email assistance.
This way, you'll simply have to follow the steps from the PS3 repair guide so you'll be able to fix your troubleshooting console literally within a couple of hours from now if you get yourself a guide right now.
Why don't you take a look at the best Playstation 3 repair guides? Visit: PS3 Repair Guide
So, in order to fix PS3 Red Screen problems, you can do 2 things. You either send your console over to Sony or a repair shop which costs hundreds of dollars and which takes 2-6 weeks. Or, you use a ps3 repair guide, save that money and be able to fix your console within a couple of hours from now if you start today.
Do you want to repair your PS3 red screen problems so you'll be able to play your favourite games again? Today? Take action by visiting: Playstation 3 Red Screen
PS3 Red Screen Of Death Fix
then you need to fix this and you can do so with a good repair guide
or send it in.
Screen check out the link below:
Hope this helps?
Article Source: http://EzineArticles.com/?expert=Jack_A_Bush
