I am re-mounting a SONY VPH D50Q to the floor from the ceiling. how do i invert the image so it is right side up?
SOURCE: Sony VPH D50Q projector doesn't see signals above 480i
HI Tom,
For some reason I cannot reply to other inquiry would you please close the problem, I am glad that the configurations worked out for you.
Al
In order to configure the proyector for hd video you would need to change a couple of things in your set up.
First you would need to use hd cables, and not the rgb. You can
purchase some standard high def cables at any best buy or radioshack,
depending on the source device there is the standard high def out, the
set of 5 cables, 3 video plus the 2 audio.
To enable the unit to support the progressive DVD signal, perform the following
procedure.
Connect the DVD player’s component output into Input A.
In the SET SETTING menu select HDTV-YPbPr for Input A.
In the INPUT SETTING menu highlight Sync and select EXT (HV).
The IDTV module disables itself automatically
Perform this procedure with nothing connected
to the component input on the projector, otherwise you will get the an
off/on flickering screen which prevents you from seing what you are
doing when navigating the menu screens. Perform the procedure and then
connect.
Let me know if you need anything else,
Al
SOURCE: I have a SONY VPH-D50 projector. Screen has green
You will probably need a new lamp.
--- Please dont forget to vote if you liked my answer thanks
thanks
