Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Upper agitator on Whirlpool Ultimate Care II washer
Upper agitator on Whilpool Ultimate Care II / Quiet Wash I washer will not agitate. Lower agitator works fine Thanks, Tony C.
Posted by tonycaro on
ROB CHRISTIAN
    New Friend:
  • Whirlpool Expert
  • 154 Answers
Replace agitator "dogs"
Posted on Mar 01, 2010
  • Janice Leigh Sep 09, 2013
    Mine is doing the same thing. What exactly are "agitator dogs"???
18helpful
2answers
How to separate auger from agitator. whirlpool ultimate care II
When you look down into the agitator, are there 4 white plastic points that look slightly melted or otherwise deformed? If so, using a small flat head screw and a small hammer, separate the white plastic from the surrounding translucent plastic. Once you've done that, it should easily pull apart.
3helpful
2answers
Whirlpool ultimate care II top load skips agitation turns
I have the same problem, and i think it is a problem with the agitator i pulled mine off, (remove softener insert below that is a seal easily removed and then a 7/16'' bolt) seems a 'clutch' mechanism between base and upper agitators is shot.
3helpful
Agitator is weak
you need to remove the agitator, then pull the top half off, replace the dogs inside the cam, and re assemble it, you can find a kit online for a few dollars.
Washer will not agitate on wash cycle
could be a belt (doubtful) or it could be the connector underneath the. if the bolt isn't tight, it could be sliding along the cutout that makes the agitator work. tip forward and check it from beneath/backside whicheverr has the easiest access to view the connections.
4helpful
Whirlpool Ultimate care II Washer Agitator not turning
replace the dogs in the top portion of the agaitator, the agaitator top comes off and you will see the four dogs part number is 285707 about 3-5 dollars
2answers
Whirlpool Ultimate care ll Quiet wash Model # LSQ9564SQ0
The ***** part of the agitator is supposed to ratchet in the clockwise direction. this is normal. If you can spin it in either direction (turned off) then you need a set of agitator dogs.
Agitator
the agitator is supposed to do that in wash dont worry
Marvin
Marvin
Mike
