WAP
***First Step***
1.Main menu --> Select Services
3.Select Data Account --> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to goam.com (lowercase), if not work, try "internet.com"
8.Edit Username to wapuser1
9.Edit Password to wap
10.Edit Auth Type to Normal
11. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
3.Select the first entry --> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to http://mymobilehomepage.rogers.com
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is 208.200.067.150 and the port number is 80
10.Edit Username to wapuser1
11.Edit Password to wap
Select back or done
Select Activate Account
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mms.gprs.rogers.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 172.025.000.107 and the port is 80
Edit the Username to media.com
Edit the Password to mda01
Select Done or Save
Make sure to activate the profile and you are good.
Restart the phone.
COUNTRY: Canada
CARRIER: Rogers
Internet Settings
APN: internet.com
USER: wapuser1
PASSWORD: wap
HOMEPAGE: http://mymobilehomepage.rogers.com
PROXY: 172.025.000.107
PORT: 80
MMS
APN: media.com
USER: media
PASSWORD: mda01
HOMEPAGE: http://mms.gprs.rogers.com
PORT: 9203
WAP
***First Step***
6.Edit the account name to whatever you would like ie Rogers John
7.Edit APN to internet.com (if not you could try goam.com (lowercase))
(note: do not need to set primary DNS or secondary DNS)
11. Save
Select Back --> Select Back àback
***Second Step***
Select WAP
1.Select Settings --> Profiles
3.Select the first entry --> edit Profile
5.edit the name to whatever you would like (ie Rogers John)
7.Edit Data Account to the Name you established in the First Step (by selecting the Data Account- Rogers John, then select GRPS from the menu, then select the data account Rogers John)
8.Edit Connection type to HTTP (enter to select this connection type, then select HTTP, then set
9.The Proxy address to 172.025.000.107 and the proxy port to 80
Select back or done and Save
***Setup MMS***
From the main homepage Select Messages --> MMS --> Message Settings
Select Profiles
Select Add new
Edit Profile Name to whatever name you would like (Rogers John)
Select Done or Save
Activate the profile
***Setup Java***
Java>Java>highlight Facebook>Network Profile
Profile mode> User specific
Select Sim1> (if the activated card is inserted in Sim1 otherwise Select Sim2)
Java Sim1 Profile >Rogers John
Restart the phone
