Televison & Video Logo
Posted on Mar 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sanyo tv model# DS32224 I BOUGHT THE REMOTE BUT NOT TURNING ON TV IS THERE A CODE I CAN PUT IN
Henry Thomas
Level 3:
Genius:
  • Master 1,074 Answers
  • Posted on Mar 01, 2010
Henry  Thomas
Master
Level 3:
Genius:
Answers
1074
Questions
Helped
336407
Points
2402
If your remote is a universal then it comes with a paper that has all codes for electronic sets including yours.if the remote is for your tv then you will have to change the batteries.if that does not turn on your tv take back the remote to the store you bought the remote from.good luck.
Where is the reset button?
Sanyo TV reset button location? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 27, 2007 - Does anyone know where to find the reset button on a 32" Sanyo TV? The thing is just totally dead and I am thinking maybe if I push the reset it ... how do i reset my sanyo flat screen television?
Dec 26, 2010
Sanyo DS32224 TV Problem!!?
May 21, 2009
More results from answers.yahoo.com
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD PLASMA TV ... video tutorial television flat-screen model # kdl ln lt lnt hp ht LINK for TV boards & Parts ... 1. soft reset - is just turning tv off & back on ..... the source by using the on/off button on the side panel, remote does not work.
Remote code
Codes to check with Sanyo are: 1171 1298 1316 1347 1349 1143
1157 1172 1208 1360 1024 1115 1052 1232 1046. If you wish to get more, http://electronicshelponline.blogspot.com/
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Where is the mode button so I can sync the remote and the tv? what is the 3 digit code
Hello
Three digit universal remote codes for Sanyo are:-
004/ 013/ 049/ 108/ 110/ 180/ 209
Four digit universal remote codes for Sanyo are:-
0049 0097 0110 0004 0268 0012 0108 0180
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NB: Switch OFF and switch ON the tv by its front panel power control switch [Not by remote control handset] each time before an other code.
OK
Wish you Happy Peacefull 2011.
Component code
codes-0154,0159 this is for the tv
32" sanyo model ds32224
picture 330 lines
video input 700 lines
16.9 full HD has 1080 resolution and this is for a ds 32224
Sanyo DS32224 tv remote
It sounds as if you have inadvertently selected the 'Aux' function. Pressing the 'TV' button (should be close to the Aux and others) should restore full control.
Since the volume generally means 'TV Volume,' this function often stays effective but the other controls will not respond, including 'Power.'
This happens to us all the time with our Dish remote which also has 4 basic functions.
1helpful
Sanyo DS32224 TV blurry
Do you have the original remote for that TV set? If you do not, you will need to get one or borrow an original Sanyo remote so you can get into the set's menu and go to puicture set up and try adjusting the constrast up a little bit.
2answers
Universal remote control
Existing 'universal' remotes will often have no codes for later TV sets; we have a number of useless 'universal remotes.'
Many of them do have a 'code search' function and you might find a code set for an unrelated TV that will give you some basic functions.
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
