The light bulbs on the above- stove inverter microwave have burnt out. They were 120v 30w. The only bulbs I could find to replace them were Sylvania 25w which fit the sockets.
However, the lamps will not turn off or dim.....could it be the bulbs causing this problem or would it have to be the switch. Note, it was working properly before the bulbs burnt out
Thanks
Bob
Just crazy bad timing...heating things on your stove makes condensation...one drop of water on the circut board is acting like the switch is on.
The actual wattage of the bulb cannot really change anything, perhaps from 10 watts to 30 watts, may, but NOT 25 watts to 30 watts, There simply isn't enough anything to detect if resistance based... I suspect your dimmer is faulty...
Testimonial: "Thanks, it seemed odd that it could just be a lower wattage bulb"
