Free
codes are harmful for your handset because if the code does not works
than your handset become hard lock & the Charges of Unlocking a Hard
lock set is normally 60$ to 90$ in the market. So don`t believe anyone
and get a mep code from a verified provider in
just 10$ to 15$. You can buy it from any
mobile shop, either from a website like http://blackberryimeiunlockcode.net/ or any other website, on website order your mep code
by entering your imei number & network which your bb locked to.
You`ll get your mep code through e-mail with
in few minutes with instructions of entering the mep code. Just
follow the instructions for entering the code & That`s it your
blackberry has now unlocked & then you can use it with any GSM Sim
card
worldwide. The Website will give you the blackberry mep code as cheaper, as well as much faster (within 1 minute)
than a shopkeeper does. Website also gives you a 100% money back
guarantee if the code does not work. This is the best way to get mep
code for your bb & unlock it from the comfort of your home. Unlocking through code is permanent means it cannot be re lock again itself!!! Click here to get blackberry mep code
Hi ashley,
Go to this link, and follow their direction to get your mep code. Usually mep code is needed when you want to unlock blackberry pearl 8100 network, however if you want simple way to unlock your phone network try to use blackberry unlock code.
Enter http://blackberrymep.com and get your code, it's cheap, don't waste your time, no one can give you a free code .
