SOURCE: Tricity Bendix washer won't take fabric softner in rinsing cycle
Your machine possibly has a defective water inlet valve which is preventing water from entering the dispenser channel to flush the fabric softner into the machine. The inlet valve in inside of your machine right where the washer hoses attach. the solenoid valves on the inlet will need to be checked with a multimeter to verify if they are working properly.
SOURCE: manual for tricity bendix 1000
Please try here:
http://www.serviceforce.co.uk/pdfs/U23248.pdf
If this is your model (there are 5 models with the same name) please rate my response.
If not, please let me know and I will find the link for your model.
Thanks.
SOURCE: tricity bendix BIW103W spins badly, clothes still too wet.
Hi, Your problem is very common and very easy to fix. You will first need to strip the machine down and remove the motor. Once you have done this then take off the motor carbon brushes, These are the little things in cases on the side of the motor casing. These should be at least 1" long! you will find that this is not the case and they will need replacing to resolve your problem. The parts should not cost anymore than around £20 for the pair.
Good luck any problems get beck to me............................
SOURCE: Our tricity bendix 1400 eco machine is not
Can you hear the pump run when it is set to drain? If so, that is a good sign. Most reasons new machines won't drain is because they are tempermental with the drains. If the slightest clog is in there, they will shut off.
You may also want to service and test the timer:
Most
washing machine timers are digital or mechanical. The timer controls
most of the operations of the washer: water level, tub filling and
emptying, length of cycles, and cycle setting sequences. For this
reason, any repairs to the timer should be made by a professional
service person. However, there are a couple of checks you can make when
you suspect the timer is faulty -- you may be able to install a new
timer yourself.
Step 1:
Unplug the washer. To access the timer, remove the control knobs and
the panel that covers the controls. This may be a front panel, or
access may be through a panel at the back of the unit. Carefully
examine the wires that connect the timer to the other parts of the
washer. If the wires are loose or disconnected, try pushing them into
position; they usually fit into their terminals like plugs. Use
long-nosed pliers to avoid breaking the wire connections -- never pull
a wire by hand.
Step 2:
To test the timer, use a VOM set to the RX1 scale. Disconnect the power
leads to the timer and clip one probe of the VOM to each lead. The VOM
should read zero if the timer is working. Since the timer is a multiple
switch, turn it through its cycle and test each pair of terminals in
turn. The meter should read zero at all of these points. If one or more
readings are above zero, the timer is faulty and should be replaced.
Step 3:
To replace the timer, unscrew and disconnect the old one. Install a new
timer made specifically for the washing machine. If there are many
wires on the timer, have a helper hold the new timer next to the old
one as you work. Disconnect the old wires one at a time, connecting
each corresponding new wire as you work, to make sure the connections
are properly made. Or, draw a diagram showing the connections before
removing the old timer. After all the wires are connected, check the
connections again for correctness and screw the timer assembly into
place.
If drain is clear, and timer is ok, then it very well could be a bad pump.
Servicing the Water Pump
Of
all washing machine parts, the water pump probably takes the most
punishment, because it is constantly in use. When the pump fails, you
can hear or see the trouble: a loud rumbling inside the machine, or a
failure of the water to drain out of the tub. Here's what you can do to
fix the problem:
©2006 Publications International, Ltd.
Take the pump apart and clean
away all debris inside the pump.
Also clear away debris from
the water tubes.
Step 1:
Check the drain hoses to make sure they are draining properly. Remove
the water supply hoses from the back of the washer. With long-nosed
pliers, extract the filter screens from the valve ports in the washer
or from the hoses themselves. Wash the screens thoroughly. Then replace
them and reattach the hoses. If the machine still rumbles or doesn't
drain, examine the pump.
Step 2:
To access the pump, first bail and sponge out any water in the
machine's tub. Then tip the washer over on its front, using a heavy
blanket or pad to protect the washer's finish. Remove the back service
panel. The pump is usually located along the bottom of the machine, but
with the unit tipped on its front it's easier to remove the pump
through the back than through the bottom of the washer.
Step 3:
Locate the pump. It has two large hoses attached to it with spring or
strap clips. If the clips are the spring type, pinch the ends of the
clips together with pliers to release them, and slide the clips down
the hoses. If the clips are the strap type, unscrew the metal collar to
loosen the clamp. Disconnect the hoses by pulling them off the
connections. If the hoses are kinked or crimped at these connections,
straighten them as best you can and reconnect them. Then try the
machine again to see if this kinking was causing the problem. If the
machine still doesn't drain, you'll have to remove the water pump.
Step 4:
To remove the pump, loosen the bolt that holds the drive belt taut and
move the washer motor on the bracket to loosen the belt. Move the motor
out of the way and unbolt the pump; it's usually held by two or three
hex-head bolts located on the bottom of the pump housing. As you loosen
the last mounting bolt, support the pump with your hand. Then lift the
pump out of the washer.
Step 5:
You should take the pump apart if you can, because the trouble could be
lint, dirt, or pieces of cloth or paper clogging the pump impeller.
Clean away all debris inside the pump and clear any debris out of the
water tubes. Then reassemble the pump. Hook up the pump again and test
it. If cleaning the pump doesn't put it back into working order, or if
the pump housing can't be removed, replace the pump with a new one of
the same kind.
Step 6:
To install the new pump, set it into position and connect the mounting
bolts to the pump housing. Move the motor back into position. Tighten
the drive belt on the motor by prying it taut with a hammer handle or
pry bar; it should give about 1/2 inch when you press on it at the center point between the two pulleys.
SOURCE: Tricity bendix aw 1001 w is not draining,pump and
If you have checked all of these then the only other explanation is that the pump motor is faulty and needs replacing or there is a fault with the wiring or Programmer.
