Question about SanDisk 4GB microSD High Capacity Memory Card
My 2gb micro SD says 'BAD FORMAT ERROR' what does it mean???
I bought a brand new 2gb micro SD from tesco, for my new LG KS360. I've had it about 2weeks and up to now it has been in perfect condition. i go on music and all of my music has gone. it wont let me access my external memory files. when i try to access my files on my memory card it says 'bad format error' i had over 250 songs and want them back badly, how can i get them back and why is my memory card saying this when it it nearly new. thanks,
Posted by kathrynwhall on
Dubewinston
    New Friend:
Wel some of your music files had viruses so it was affected what u can recover is your memory card and nothing else.use your computer to formmat it.
Posted on Jun 05, 2011
Anonymous
  • 20 Answers
Mine 2 that also happened 2 meT_T please help us!!!!!
Posted on Mar 28, 2010
My 2gb sandisk micro SD card reduce the size after formatting
Possible micro SD bad sectors. To check your micro SD bad sector or not, you use the HD Tune software. To restore the capacity micro SD, which is done is Low Level Format. You can use the software HDD Low Level Format Tool.
How to use HD Tune and HDD Low Level Format, you can see here
Transcend Repair Bad sectors
How to repair micro SD, you can see in here
MMC Repair Without Losing Data Video 2
Oct 12, 2011 | SanDisk 2GB microSD Memory Card
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
I CANNOT FORMAT MY MEMORY CARD FOR A KS360
What's the capacity of the memory card which you are trying to format?
The largest capacity which your phone is capable of using is a 4GB micro SD. It will not work at all with larger capacity cards which are all of the newer SDHC standard and there is room for confusion as both 4GB micro SD and micro SDHC cards are widely available.
Incompatibility with SDHC is a hardware issue: there is no way to upgrade phones which are incompatible with the later specification.
I hope that you have found my answer to be of assistance and ask in return only that you take a moment to rate my answer. If my advice has not helped then please add a further comment with details of the exact make and model of SD card and I'll do my best to provide further assistance.
Oct 08, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
I have an LG KS360, and have bought a 2kb memeory sd for it, but it stills says memory full when trying to bluetooth any song on it?
copy your songs from the memory of your phone on your sd card and its a 2GB sd card right not a 2kb? and if you have to much songs buy a higer sd card but first look of you mobile phone can handle it
Aug 28, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
My lg ks360 webslider wont read my external memory
Hi , I just had the same problem with my son's webslider and found this solution. Go to Settings-Memory Status(which is way down the bottom out of view, just keep scrolling down)-External Memory. Once selected you should see how much memory is available. Down in the lefthand corner is 'Format' select this and it will prepare your micro SD card for use in the phone.Make sure you turn the phone off after formatting and restart it, just as you would when installing new software on a computer. Cheers!
Aug 10, 2009 | Lands Phones
What memory card does ks360 take pls
Your LG KS360 accepts Micro SD cards.The largest Micro SD card you can use in your LG KS360 is 2GB
Jun 26, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Lg ks360
I had a similar problem, I would plug it in and the screen would sometimes flicker on the KS360 logo but would otherwise remain dead. I removed the Micro SD card I put in it and now it seems to be working fine. If you've got one in there, try removing it, might help.
Jun 20, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
KS 360 won't recognize my micro SD card
best to back it up on your computer then FORMAT the sd card when inserted into your phone
Apr 25, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Micro sd 4gb micro card.
Something is wrong with the card. Maybe it's corrupted.
But what your computer means by I/O Error is Input/Output Device Error, which means the card has issues.
Hope this helps!
Jan 27, 2009 | LG VOYAGER VX10000 Cellular Phone
SanDisk 4GB microSD High Capacity Memory Card Logo
2,564 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Marvin
Marvin
ChinthakaJ
ChinthakaJ
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
